Conclusion to Turbine Wheel Differences in Van & Truck Turbo
First off, check this thread if you're wondering what I'm talking about to catch you up to speed: https://www.ford-trucks.com/forums/s....php?p=3679917
The o-rings came in over the weekend, so I went to work pulling the turbo off the truck so I can compare the two. I found some interesting results.
First thing I did was to pull the 1.15 A/R exhaust housing off my truck turbo to see if it would fit the van turbo. This would tell me if it really was designed for the truck turbo, or if it was just a van turbo. Much to my suprise, it didn't fit the van turbo. So, it really was designed to fit the different trim of the truck turbo's exhaust wheel afterall. Just to be sure, I then dropped the van turbo housing onto the truck turbo. There was a noticeable gap between the vanes and the housing. I can see how this would cause a loss in boost. However, the housing designed for the truck didn't have that gap at all.
But, since I had the turbo's all out and apart on the bench, I decided I'd put the van turbo back on just to see if there is a difference in performance, since it does actually have a slightly larger turbine wheel. To make sure the only difference I was testing was the exhaust side, I used both the compressor wheel and the ATS housing that were on my truck turbo.
Reinstalled everything and took it out for a drive. There is virtually no difference in performance. Peak boost numbers didn't change, EGT's didn't change, and lag is virtually the same. Turbo lag may be just a little more, and I mean just barely, with the real van turbo, but it's only noticeable because I was specifically looking for it. The only place I noticed it was in the 80 HP setting on the chip, trans in OD, the truck turbo with the 1.15 housing would not really light until about 55-56 MPH. The van turbo lights hard at about 59-60 MPH. That's the only place I noticed any difference in the way the turbo performs.
So my conclusions are this: the 1.15 housing that Shop Diesel sells is really designed for our truck turbo, and I wasn't losing any boost. It and the van turbo perform nearly identical. Since the van turbo's what's on the truck now, I'm leaving it in place. I'm out a bit of money, but to me it's worth it to know for sure what I've got, and also to be able to pass the information on to you all. Which would I do if I had to do it all over again? Depends on which I can get cheaper. When I bought the housing for the truck turbo, it was cheaper than what used turbo's were going for on eBay. But, if the van turbo is cheaper, I'd get it.
Originally Posted by mech2161
You need to check drive pressures to see if there is any real difference. Connect a boost gauge in the exhaust tube that you plugged to read the drive pressure. If they seem to be the same in performance the lower pressure is the one you want.
Question about the drive pressure gauge. How did you keep the soot out of that little tube, and how did you keep it from melting? I guess I could always just use and electric gauge. Convenient that it's a 1/8" NPT port on that little tube.
Thanks Kevin. I'll try the copper route for sure. Drive pressures are something that I'm definately going to want to start paying attention to as the buildup of this engine progresses.
Wilhntr, yes it did require an adapter of some sort. Same type as the van turbo's use. I used the same piece on both the SD housing and the van turbo.
Yellow, I don't know about what I'm planning for the future. Developmends and advancements in turbo knowledge for our PSD is happeneing at a rapid rate right now. I'll end up looking at what's out there when it comes time to do the turbo. Plans for the engine are quite big, and include some big oil, bigger injectors, more fuel flow, and other supporting mods. I was originally looking at the QSSB from Wide Open Performance, but they have now come out with a KASB that is supposed to be a little better than the QSSB. Of course Black Widow Diesel, DI Performance, Bean's Diesel, and Wide Open Performance all have some new stuff in the works. It will be 6 months to a year before the upgrade happens, and a lot can change in what's out there by then. The point of me switching to the van turbo was to get me by with what I have now, and also to get me through and then survive as other mods happen, before I have to drop some big bucks for a new turbo.
Kris, I figured you'd be happy with the results. I know you figured we were ok, but I just had to know for sure what was going on. I'm glad I now know, even if it did cost a little bit of $$$.
