Sponsored by: Auxito
FUEL PUMP TESTING?
Old Aug 19, 2010 | 04:44 PM
robjs111's Avatar
robjs111
FUEL PUMP TESTING?
Anybody know how to test a fuel pump on a 98 F150 4 x 2 4.6 auto?
Thanks.
Old Aug 19, 2010 | 07:32 PM
Bluegrass 7's Avatar
Bluegrass 7
The absolute proper way is to measure how much fuel it pumps per unit of time but few do it that way.
Here is some guidelines.
1. check the fuel pressure on the injector rails for a PSI of about 40 +/- a few.
2. Check how much pressure is pumped at key on position but no start.
3. Check the pressure bleed down rate after the motor is stopped.
These checks will provide a good indication of the health of the whole system.
Good luck.
Old Aug 19, 2010 | 08:44 PM
robjs111's Avatar
robjs111
What should fuel pressure psi be with key on no start?
What kind of bleed rate psi am I looking for after motor off?
Old Aug 19, 2010 | 09:30 PM
steve(ill)'s Avatar
steve(ill)
when you turn the key to "on" the pump starts and runs for 3-4 seconds. you will see 40 psi at the fuel rail. turn the pump off and that pressure should remain. i think 1 psi drop per minute is the "normal" spec.
jerrytown2001
Jan 6, 2012 10:57 AM
chip99
Jan 9, 2011 02:28 PM
wedwebel
Apr 9, 2008 07:40 PM
elzss
Bronco II
15
Apr 19, 2004 04:50 PM
