Rust Spots on Ceramic Coated Headers
Old Aug 18, 2010 | 11:10 AM
LARIAT 85's Avatar
LARIAT 85
I bought a nice set of ceramic coated Thorley Tri-Y headers two years ago. I am very happy with these so far and have experienced no leaks.
However, a few small rust spots are beginning to form. Is there a way to remove this, like is there some sort of polish or something for ceramic headers?
Old Aug 18, 2010 | 04:33 PM
dkf's Avatar
dkf
Nope.
The rust will continue to expand and get worse. Every single ceramic coated header I have rusts. I have Thorleys on my truck now and within 6 months I was under the truck brushing the rust spots and spraying on header paint.
Old Aug 18, 2010 | 09:32 PM
LARIAT 85's Avatar
LARIAT 85
Wow. I guess I wasted my money when I payed extra for the ceramic coating.
Does header paint actually work? I have never seen a paint that could actually last on a header.
What is your method for repairing rust on your Thorley's?
Old Aug 19, 2010 | 11:41 AM
dkf's Avatar
dkf
Brush off as much rust as possible and spray on some header paint. You can take the spot down to bare metal to remove all rust and then paint it.
The ceramic coating that comes on the headers is a basically a ceramic fortified paint that is put on, baked and put into a vibratory media of some sort to polish it up.
Old Aug 19, 2010 | 12:40 PM
LARIAT 85's Avatar
LARIAT 85
Thanks, dfk.
Is there any particular header paint that you have had better luck with that you can recommend?
Old Aug 19, 2010 | 02:52 PM
dkf's Avatar
dkf
I have been using the VHT 2000 deg Ceramic header paint in the Aluminum color. I tried Duplicolor before and it looked nicer but didn't hold up as long as the VHT does. Duplicolor bought VHT so I don't know if Duplicolor even makes header paint under the Duplicolor name anymore. Most of the major anuto parts stores have it.
46Whizzer
Jan 17, 2016 03:02 PM
greentruck72
Apr 11, 2015 01:23 PM
RAGrove
Exhaust Systems
Oct 10, 2014 07:49 PM
Diesel 724
Oct 7, 2014 07:13 AM
parkland
Sep 22, 2009 07:10 PM
