EBPS Delete
Old Aug 22, 2010 | 02:37 PM
BlueMule's Avatar
BlueMule
Originally Posted by 427 fordman
What does that sensor do then?? Is it just to activate the ebpv?
Yep! That's all it does. The sensor detects the throttle position by reading the exhaust pressure in the manifold, then the PCM uses that info along with info from the EOT sensor (engine oil temp) and IAT sensor (intake air temperature) to determine when to open and close the back pressure valve.
Old Aug 22, 2010 | 02:59 PM
BlueMule's Avatar
BlueMule
Originally Posted by 95PSDieselP
Thank you. That's what i wanted to know. Do i just leave the plug sitting there or do i jump it or what?
Don't jump it, either just leave it hanging or clip the wires at different lengths and wrap them separate and tuck them back into the harness. Have you unplugged the wire EBPV regulator?
Old Aug 22, 2010 | 05:44 PM
95PSDieselP's Avatar
95PSDieselP
No i have not I do not know where it is.
Old Aug 22, 2010 | 06:28 PM
BlueMule's Avatar
BlueMule
There are two wires that go from the actuator on the EBPV. they go under the turbo, thru the valley and into the harness that goes to the drivers side injectors. Near the head is a two wire weatherpak connector, once you unplug it the EBPV will default to the open position.
There are some pics floating around on the web but I'll have to look and see if I can find them again.
Old Aug 22, 2010 | 06:55 PM
BlueMule's Avatar
BlueMule
Here Ya go:
Gutting the Exhaust Back Pressure Valve - 1994-1997 Power Stroke FAQ
And unless you plan on using the valve as an exhaust brake you might as well go ahead and gut it.
Old Aug 22, 2010 | 07:37 PM
95PSDieselP
wow man thank you so much for the help it was a big help. and this will not throw any codes or anything will it?
Old Aug 24, 2010 | 06:16 AM
BlueMule's Avatar
BlueMule
I don't get a code for the missing sensor but I do get one for having the actuator unplugged (P0475) It's just a soft code though and doesn't set the CEL.
Old Aug 24, 2010 | 11:27 AM
B Big's Avatar
B Big
Would this be a good place to mount the pyrometer?
Old Aug 24, 2010 | 04:39 PM
BlueMule's Avatar
BlueMule
No not really, in the manifold would be better. piston temps are what you need to worry about so the closer you can get to the head the better you'd be.
I had one mounted in the top of the EBPV valve but I also had one in the drivers side manifold and a dual gauge to go along with them.
JD_F250
Oct 27, 2014 06:33 PM
Blitzcraig
Feb 8, 2012 11:18 PM
F-250 Super Duty
46
Jul 20, 2011 08:02 PM
Gary A.
Feb 29, 2008 09:44 PM
buck_
Nov 24, 2007 08:23 AM
