Coolant flow direction through oil cooler?
Old 08-17-2010, 10:05 PM
plgebbia's Avatar
plgebbia
plgebbia is offline
I was stupid and didn't mark which end was which..... so I need to know which direction the coolant flows through the cooler?
BTW, can the tube be installed either way? or could it cause a problem by switching the flow direction?
Thanks,
Old 08-17-2010, 10:36 PM
95PSDieselP's Avatar
95PSDieselP
95PSDieselP is offline
What year is it
Old 08-17-2010, 10:42 PM
plgebbia's Avatar
plgebbia
plgebbia is offline
nineteen ninty five, had to get at least 10 characters
Old 08-17-2010, 10:46 PM
Munch 97's Avatar
Munch 97
Munch 97 is offline
how often do you change your coolant?
Old 08-17-2010, 10:53 PM
95PSDieselP
[IMG]file:///C:/Users/Reese/AppData/Local/Temp/moz-screenshot.png[/IMG][IMG]file:///C:/Users/Reese/AppData/Local/Temp/moz-screenshot-1.png[/IMG]
Old 08-17-2010, 10:55 PM
plgebbia's Avatar
plgebbia
plgebbia is offline
This is a project truck and I don't know the history of it, but I will be putting in new coolant. I need to know which way the coolant flows so I don't have any problems when I get it running.
I haven't kept one truck long enough to change the coolant more than once, but If the coolant is good quality I would change it every 50,000 or so.
Old 08-17-2010, 11:02 PM
95PSDieselP
Well i posted a diagram i do not know if you can see it.
Old 08-17-2010, 11:08 PM
plgebbia's Avatar
plgebbia
plgebbia is offline
Thanks, I can see it, I just need to know if the coolant flows from the front to the back, or vice versa.
Old 08-17-2010, 11:13 PM
95PSDieselP
i think from the back to the front i am not positive sorry
Old 08-17-2010, 11:14 PM
95PSDieselP
Front to back
Old 08-17-2010, 11:18 PM
plgebbia's Avatar
plgebbia
plgebbia is offline
Thanks!!!!!
Old 08-17-2010, 11:24 PM
Munch 97's Avatar
Munch 97
Munch 97 is offline
ok sounds good i had a 1989 F-350 7.3 no turbo i traded it for the 97 much better truck less problems but just not up on the power stokes
RP27G8G
Modular V8 (4.6L, 5.4L)
13
03-18-2017 11:14 PM
syjl
08-29-2015 12:07 PM
MC5C
03-23-2013 12:34 PM
brickie
05-08-2012 12:40 PM
bismic
03-30-2012 02:18 AM
Quick Reply: Coolant flow direction through oil cooler?
