Sponsored by: Real Truck
Tires Splitting/Cracking?
Old Aug 17, 2010 | 08:41 PM
Robs06SuperDuty's Avatar
Robs06SuperDuty
I just noticed today that quite a few places on my tires (Cooper Discoverer STT) are cracking/splitting in front of the tread lugs, mostly in the center lugs. They range fron about 1/4" to about 5/8", looks like the carcass is slowly seperating.
I've got over 30K miles on the tires and they still have a good bit of tread left, but this has me a little concerned... they get rotated every 5K religiously and I try to keep up on the air pressure as much as possible. Ill try to get pics within the next day or 2.
what do you guys think?...
Old Aug 17, 2010 | 09:08 PM
DAVE67FD's Avatar
DAVE67FD
Kind of strange,
But you may want to check the date code of the tire.
I have read of some people purchasing 5 year old tires.
Tire Tech Information - Determining the Age of a Tire
It may also be a combination of the climate you live in, where it is parked and possibly different compounds or cleaners you may use.
Unless your doing the rotate yourself i wouldn't spend the money to have them rotated every 5k but more like 10-12k.
Old Aug 17, 2010 | 09:10 PM
Robs06SuperDuty
these are the first tires ive had ever do this, I rotate them myself. Only reason I do 5K miles is cuz there a MT. Thanks for the link Dave.
looks like ill be getting new tires sooner than I expected. Last thing I need is tires flying apart and my truck getting eff'd up.
Old Aug 18, 2010 | 07:54 AM
BareBones's Avatar
BareBones
You mentioned pictures...?
Old Aug 18, 2010 | 12:24 PM
Robs06SuperDuty
wont be able to get them today, its raining right now. ill have to take some after I get off work.
Old Aug 18, 2010 | 12:34 PM
Kajtek1's Avatar
Kajtek1
That usually is combination of age, poor quality and UV (sun) exposure.
I do own vintage bus conversion, where for the experiment I keep one original tire on tag axle. The tire is so old, that nobody can decode the vintage DOT number. It is about 30 years old and still holding 80 psi of pressure for whole year.
But this is the size used in commercial trucking, where new Michelin cost me $550 a piece.
Common car tires have 6 years age warranty. Read the DOT numbers, or post the darn pictures.
Old Aug 18, 2010 | 02:44 PM
cartmanea's Avatar
cartmanea
What tire pressure do you run? Could be too low causing the tires to get hot from excess flexing.
Old Aug 18, 2010 | 04:27 PM
dkf's Avatar
dkf
Make sure you check the sidewalls for cracks. I have had issues with 2 sets of coopers (8 tires) where the sidewall started developing cracks in less than 6 months. Cooper put out some bad tires and getting a dealer to warrenty them can be a pain.
Old Aug 18, 2010 | 05:23 PM
Robs06SuperDuty
I run between 55 and 60 psi, back in the winter I aired them down to 45 cuz of the deep snow. Sidewalls are fine, All 4 of my Coopers have cracks in them, the one front has 5 that I saw. I checked the age and they were made in 09, I got them in July of 09 so age is not a problem.
Im thinkin about ordering a set of Hankook Dynapro MT's as a replacement for my Coopers.
I wanted to get pics today but its raining and im at work now. supposed to rain all week.
Old Aug 18, 2010 | 06:09 PM
redford's Avatar
redford
FTE Leadership Emeritus
So, did you get a date off of the tires?
truckfella
Modular V10 (6.8l)
19
Oct 18, 2014 07:55 PM
1Knight
Dec 2, 2013 07:12 AM
Redmanbob
May 3, 2013 12:09 PM
Brother Les
16
May 22, 2012 07:51 PM
YoungMT Hick
May 16, 2009 07:39 PM
