Inverter Install Questions
Old Aug 17, 2010 | 02:01 PM
DemonRace6's Avatar
DemonRace6
Hi!
I want to run a large air compressor for my large penumatic pump for work, some options:
1)10+ CFM @ 90 psi Gas powered (~$1000)
2)2 Large cheap eBay inverters ($800)
240v 10+ CFM @ 90 psi compressor ($800)
Total of about $1600
3)7.1 CFM @ 90 psi 110v portable air compressor $600
Large cheap eBay 8000w inverter $400
Total of about $1000
I would rather electric, but I am not sure how the inverters would drain my batteries. I have a 200 amp alternator installed which should help. Has anyone used a large inverter to run big stuff like this? Anyone permanently mount the air compressor?
Old Aug 17, 2010 | 02:31 PM
Nick 99's Avatar
Nick 99
You will have to fill the entire bed of the truck just have enough batteries to support that much load. You would be far better off going with the gas powered compressor.
Locked rotor currents to start a compressor would smoke the inverter in no time. Inverters were just not designed to deal with that kind of abuse.
Old Aug 17, 2010 | 02:56 PM
bobbyrjw's Avatar
bobbyrjw
For less than $400, you could by a small generator or a used big one. Much more practical than a big invertor.
Old Aug 17, 2010 | 03:52 PM
DemonRace6's Avatar
DemonRace6
Hi!
OK, probably going to go with the generator then so I can run other appliances and tools. Thank you!
dingfangle
1961 - 1963 F100 Unibody
17
Jan 23, 2011 09:55 PM
K8's Ford
13
Oct 19, 2010 05:39 PM
96_4wdr
Aerostar
Jun 24, 2007 04:33 PM
Dano1
May 16, 2005 10:56 PM
YOMAN
2004 - 2008 F150
Sep 4, 2004 12:28 PM
