Transmission lost all forward movement
Old Aug 16, 2010 | 09:45 PM
F350mikey's Avatar
F350mikey
Hello everyone, maybe some one can shed some light on my problem before I take it to the shop.
I have a 2001 Ford F350 4x4 dualley with the 7.3 Powerstroke, am unsure what model the transmission is. Went on a 5 day trip pulling my 26 foot pull toyhauler, I always use the overdrive lockout when pulling. Got home and was putting my toyhauler back in its resting spot by my house. I was in reverse stoped the truck and placed it into drive, it did not move so I gave it a lilltle gas thinking I was in a hole, it clunked into drive and moved forward, repositioned my trailer and I placed it back into reverse to move the toyhauler back into position. Went to place the truck back into drive and nothing, it acted like it was in neutral. Placed truck into low and 2nd with the same affect. Placed truck into 4 low and 4 high still with the same affect. Check the fluid and the level was correct, was bright red and did not smell burned. I checked the truck when it was cold and still the same affect. I thought there might be a module or cylinoid I could check, if not what gives? Any help would be greatly appriciated. Thank you in advance.
Old Aug 16, 2010 | 09:48 PM
BigAlsPSD's Avatar
BigAlsPSD
May have "adjusted" your shifter cable linkage at the transmission, what happens if you try to stick it in 2nd lets say, that may act as though it were in "D", just a start
Old Aug 16, 2010 | 09:55 PM
F350mikey's Avatar
F350mikey
That might be a good idea to try and readjust my linkage, put reverse and park still works. I was thinking that there is some type of module that the linkage connects to, I was wondering if that could be bad?
Old Aug 16, 2010 | 09:57 PM
BigAlsPSD's Avatar
BigAlsPSD
If this is the case that "2" is actually drive and I hope it is, check out this https://www.ford-trucks.com/forums/8...djustment.html for some info on adjustment
This thread as well has some helpful info.
https://www.ford-trucks.com/forums/6...djustment.html
Old Aug 16, 2010 | 09:59 PM
BigAlsPSD's Avatar
BigAlsPSD
The cable could have been knocked out of adjustment toward the long side which is P side, and you dont have enough through to get into D, like I said just a first thought and an easy check. If you have a "helper" you could disconnect the cable and try to shift it "manually" with the lever.
Old Aug 16, 2010 | 10:04 PM
cps's Avatar
cps
Same sort of thing happened to me a couple of years ago. The OD sungear failed. Tranny was toast. I hope that is not your problem.
Old Aug 16, 2010 | 11:13 PM
mueckster's Avatar
mueckster
I had the Forward Clutch feed bolt in the case come loose and exihibit the same problem. Worked fine in reverse, but no forward.
Old Aug 17, 2010 | 12:19 AM
erbilabuc's Avatar
erbilabuc
did all you have to do was tighten it back up? Is that bolt acessible through the pan?
Old Aug 17, 2010 | 12:30 AM
itsjustdan26's Avatar
itsjustdan26
Maybe your TC just blew up?
Old Aug 17, 2010 | 06:37 AM
Mark Kovalsky's Avatar
Mark Kovalsky
Frmr Ford Trans Engr
If the TC blew up how would it still work in reverse?
Old Aug 17, 2010 | 07:04 AM
Franko72's Avatar
Franko72
Molon Labe
Glad you made it home before it stopped working...
I lost my forward gears Saturday also....
Its in the water.
Let us know what you find.
Old Aug 17, 2010 | 04:48 PM
F350mikey's Avatar
F350mikey
Thanks for all the posts, and yes I am glad I made it home. Just got off of work and am going to look into the linkage now, could not hurt.
Thanks Agian
Old Aug 17, 2010 | 05:03 PM
trackspeeder's Avatar
trackspeeder
This happens often. Re tighten to spec good to go again.
Old Aug 17, 2010 | 11:27 PM
mueckster's Avatar
mueckster
You have to drop the valve bodies and separator plate to access the bolts. There are check ***** above plate that will fall from the case when the plate is removed. If you decide to do this, I can provide you with a pics of their proper locations and torque specs.
I would replace the bolt with a new one. It comes with a sealant on the threads. They aren't very expensive anyways. Tightening may be only a temporary fix, if you don't correct the problem as to why it loosened up in the first place. Here is some pics and text into the reason my bolts loosened. http://s571.photobucket.com/albums/s...nd%20Upgrades/ The bolts, that loosen, screw into the center support housing.
Old Aug 17, 2010 | 11:39 PM
itsjustdan26
I was able to only go in reverse. No forward gears.
