Computer Chips & Tuners
Speedo Correction
Old Aug 16, 2010 | 05:37 PM
Beatdown Z's Avatar
Beatdown Z
Speedo Correction
I'm thinking about regearing my '98 E250 5.4l work van with 4.56 gears. What are my options as far as correcting the speedo? I also want to prevent any shifting issues that may arise from having a different ratio from stock.
Old Aug 16, 2010 | 06:02 PM
shotgunz's Avatar
shotgunz
Hypertech makes a 'device' (not a tuner) that can change the GR and TS.
Speedometer Calibrator - Hypertech
Old Aug 23, 2010 | 11:53 AM
fiveohpoepoe's Avatar
fiveohpoepoe
Only part to that is the 1998 model. Most of the programmers do not have the adjustments for our years and started in 99. I only skimmed the link you posted, but did not find anything to say it would not work. I sent them an email asking.
Old Sep 2, 2010 | 09:43 AM
X-Hibition's Avatar
X-Hibition
If you read in the forums then speedometer correction is as simple as going in to the dealer.
The first dealer I went to charged $65.00 to make the correction, oops, called me back and said they could only correct up or down 1/2 inch (not helpful with 35s). No work, so no charge.
The second dealer said they could correct up to 35" and it cost $95.00. After dropping it off, they called, I came back, paid and drove down the road. And immediately realized the speedo was still off by the same amount. Drove right back to the dealer to tell them and the first thing they say is here is your money back.
I, of course, don't want the money, I just need the speedo corrected. I am not given access to the wrench, no one will go for a test ride, just take your money and go. And I did.
Old Sep 2, 2010 | 09:58 AM
fiveohpoepoe
I called a company that specializes in speedo gears. Told them what my set up is and it took about 15 seconds for him to say I needed a 17 tooth. Got one and put it in. Now Im good to go.
Hypertech does not have anything that will work on a 98. 99+ models
Old Sep 2, 2010 | 10:39 AM
shotgunz's Avatar
shotgunz
Good information!
Old Sep 12, 2010 | 01:49 AM
Beatdown Z's Avatar
Beatdown Z
Alright, so the dealership may or may not be able to correct it?
I didn't check, but I assumed it doesn't have speedo gears. I'm thinking it only has speed sensors?
Oh yea, the tire size will be 245/75R/16 or 30".
Old Sep 12, 2010 | 07:15 AM
5 Star Tuning's Avatar
5 Star Tuning
Former Vendor
On most of the van we have tuned the PCM controls the speedo output which means we can correct speedo, gear changes and shift points. Find your PCM code and email me and i will pull it up to confirm.
thanks
Mike
ford4ever_2003
Mar 28, 2012 06:40 AM
Fox_Racing
Jan 15, 2009 09:16 AM
Bobby82490
1997 - 2003 F150
Sep 4, 2008 07:30 PM
881504x4
Feb 25, 2005 05:25 PM
joetee10
Mar 7, 2003 02:11 PM
