4WD problem
Old Feb 15, 2003 | 04:05 PM
rberghef's Avatar
rberghef
4WD problem
I have a 96 Explorer XLT V6. It has developed a problem with the 4WD. When I
put it into 4WD high the light comes on but does not engage the front
wheels. I can then put it in N and switch it to 4WD low and can hear the
actuator motor switch to Low 4WD, I also see the light on. Again the front
wheels do not engage. Have removed the actuator motor from the transfer case
to check and see if it works and it does. So I put the truck up on stands
and wanted to see if the front wheels turn and they did. So a friend and I
put pressure against the tires and were able to stop the tires. I am at a
lost what could be the problem, any suggestions?
Old Feb 15, 2003 | 08:36 PM
mrshorty's Avatar
mrshorty
4WD problem
Did the '96 Explorer use the vacuum disconnect on the front axle?
Old Feb 16, 2003 | 10:24 AM
rberghef's Avatar
rberghef
4WD problem
Yes, there is two vacuum lines attached to a round object that is connected to the front axle. I have check the vacuum on these lines and seems to have some vacuum there. I do not have a tester to see how much vacuum.
Old Feb 20, 2003 | 07:11 PM
Billy177's Avatar
Billy177
4WD problem
that would be the first thing to check but if it is 4x4 auto it will only engage when it needs to
when was the last time you changed the transfer case fluid
Old Feb 21, 2003 | 09:37 AM
CNTHOR's Avatar
CNTHOR
4WD problem
You should not be able to stop the tires. The vacuum shift motor on the front axle is driven open and driven closed. That means there will always be a vacuum on one of the lines going to the motor. I think that's where your problem is.
If you follow those lines back up to the Vacuum shift relay It might be bad. I think you can bypass it and send vacuum to each line directly and see if your front axle engages.
gpdickert
1983 - 2012 Ranger & B-Series
Jul 4, 2013 09:01 PM
dannyboy_86
1997 - 2003 F150
Jan 28, 2012 02:23 PM
mothra
1997 - 2003 F150
Jun 15, 2011 09:37 AM
cougar1985
1997 - 2003 F150
Dec 6, 2009 12:41 PM
woody24
2004 - 2008 F150
Oct 5, 2008 08:22 AM
