E4OD slipping
Old Aug 15, 2010 | 10:27 PM
f1504x4driver's Avatar
f1504x4driver
Proud Pirate
E4OD slipping
My trans is slipping from 1st to 2nd only. When it does shift at times it is so hard it feels like it is going to snap the u joints. It shifts fine other than this and does not do it all the time. I have changed the fluid and filter, the tps and it has had no effect. Local trans shops cannot agree what is wrong but they are all sure it will be expensive and require a rebuild. The computer is not showing any codes.This is my only transportation and I am at a loss. Currently i am starting out in second and then shifting and it works fine. Please help, any advice would be appreciated.
Old Aug 17, 2010 | 09:27 PM
f1504x4driver
Proud Pirate
cant anyone help? any ideas or suggestions?
Old Sep 3, 2010 | 08:18 AM
bmac6446's Avatar
bmac6446
My '94 did that for about a year! I dropped the pan, changed fluid and filter.... Whaaam! Still did it. Out of the blue and in any gear. Change out your MPLS on the transmission. It took me about an hour or so to do mine. Now it shifts like butter! Check this link out: E4OD troubles - Ford F Series Zone - F150 F250 F350 Super Duty Ranger Tech
I bought mine here: Switch, E4OD Manual position lever, PRND21 Switch, 1989-96 | Switches & solenoids | Bulkpart transmission parts
The kit comes with a new grommet that prevents any water intrusion into the module. It's not that hard to do yourself. Just remember to block your tires and leave the shifter in neutral when you replace it.
Old Sep 3, 2010 | 08:23 AM
bmac6446's Avatar
bmac6446
By the way, the problem finally did cause my F250 to break the rear most u-joint on my way home from work. It happened one week after I fixed the problem. Go figure. Check your drive line when you get the module replaced for cracks or excessive slack.
monopoly
Oct 23, 2011 12:52 AM
true blue
Aug 20, 2006 08:23 PM
bigbuick
Oct 19, 2005 09:45 PM
dsmith1484
May 29, 2003 12:19 AM
