code p0676
Old Aug 15, 2010 | 08:25 PM
foul1's Avatar
foul1
code p0676
What this usually mean for a fix? Cylinder 6 Glow Plug Circuit
Old Aug 15, 2010 | 08:50 PM
bismic's Avatar
bismic
Faulty circuit, bad glow plug, OR a bad GPCM.
There have been somewhat frequent wire chaffing issues. Have you checked the wiring?
Old Aug 15, 2010 | 09:34 PM
m-chan68's Avatar
m-chan68
The red bold highlight would be the most likely scenario. I can count on my hands how many glow plugs I've ever had to replace on a 6.0L engine out of thousands that I've wrenched on so far, namely ONE.
But to diagnose that code requires simply checking glow plug #6 harness (glow plug end) resistance to ground. You should see between 0.5 to 2.0 ohms. If this checks out good, check for continuity between the GPCM and cylinder #6 glow plug circuit on the main engine harness itself. And if that checks out good, replace the GPCM.
Old Aug 15, 2010 | 09:38 PM
foul1's Avatar
foul1
I wouldnt have even known had I not gotten the sct. Where would be the most obvious place to start looking for the chafe to eliminate it first? Would only one code mean only one is not working properly? Can I do any damage?
Old Aug 15, 2010 | 09:43 PM
joe blow's Avatar
joe blow
Thank M-Chan for helping out with your knowledge.....rep points given.
Old Aug 15, 2010 | 11:29 PM
BLADE35's Avatar
BLADE35
When i took mine apart for some injector work i found that the wire was starting to chaf on the harness about 1 or 2 inches before it pluged in to the GPCM right at the harness mount hope this helps
Old Aug 15, 2010 | 11:32 PM
foul1's Avatar
foul1
Thank you. I would give rep points also but I need to know how to do that too.
Old Aug 16, 2010 | 05:57 AM
npccpartsman's Avatar
npccpartsman
If you'll look to the right of his screen name on his post you'll see a red heart--click it and it will give you options about his post.
Aerostar
Aug 21, 2024 11:23 PM
bradphx
67
Jan 10, 2024 06:12 PM
Mar 9, 2016 12:40 PM
miko6810
Modular V10 (6.8l)
Jun 4, 2014 06:14 AM
Roachfood
Mar 11, 2002 10:21 PM
