trailer plug wiring
Old Apr 1, 2017 | 02:14 PM
c_land's Avatar
c_land
Originally Posted by subford
If you do not have the towing package then no there is not and the BLUE wire for the breaks stops at the safety wall.
If you have the towing package the you will have the small relay box beside the big fuse relay box and wires plugged into the two plugs (C149 & C105) on the drivers inter fender.
Wiring with and without the tow package.
If if I just clip the blue wire at the cab side of the fire wall and run blue wire to the back will I be able to run my controller off the factory plug under the dash?
Old Apr 1, 2017 | 02:16 PM
c_land's Avatar
c_land
e.g. Clips here and connect wire from the back.
Old Apr 1, 2017 | 03:02 PM
subford's Avatar
subford
Yes you can do that.
Old Apr 1, 2017 | 03:09 PM
GuyinWy's Avatar
GuyinWy
I don't have the factory tow package on my '97, but I plugged my brake controller into the plug under the dash and it does work without any additional wiring. You might check it with an ohm meter before you start splicing wires.
Mr Al
2015 - 2020 F150
17
Dec 14, 2017 10:14 AM
Derrick Stiriz
Feb 14, 2017 04:29 AM
Trath67
Dec 18, 2016 04:23 PM
otnot
Dec 12, 2016 01:54 PM
460jared96
Nov 20, 2016 12:09 AM
