Is this the right intake?
Old Apr 1, 2017 | 12:21 PM
GuyinWy's Avatar
GuyinWy
I'm at the junk yard hunting for a 5.0 upper intake to port to match my 5.8 lower. Is this the correct one?
Old Apr 1, 2017 | 05:13 PM
Conanski's Avatar
Conanski
Yes.. squareish runners means it is a 5.0 but.. the 5.8 lower is the part you will be porting.. not the 5.0 upper.
Old Apr 1, 2017 | 06:07 PM
GuyinWy's Avatar
GuyinWy
Thank you sir. I'll have to go back and get it, I didn't have a Torx with me that would work.
Is the 5.0 upper a worthwhile investment of time or would I be better off buying aftermarket? I've read about the Typhoon intake as an alternative to the Edelbrock, but since my goal is low end torque I'm not sure if the Typhoon is a good choice. Looks like it was made for a Mustang?
Old Apr 1, 2017 | 06:32 PM
My4Fordtrucks's Avatar
My4Fordtrucks
Is that an '86 intake? If I recall my '87 had the 5.0L cast into it.
Old Apr 1, 2017 | 08:00 PM
Conanski's Avatar
Conanski
The lower portion is the choke point in the stock 5.8 intake but it's not just the size of the ports but that shape too.. they are kinked too sharply so there is only so much you can do with it. Total runner length for the stock Ford intakes and the Eddy Performer and Typhoon are pretty much the same.. within an inch of each other so given the increase in airflow you get with an aftermarket intake torque output will increase as well. Besides, the cam, engine displacement, and cylinder head airflow are the primary factors determining an engines powerband, everything else including intake runner length just messages that a little.. same way exhaust header tube length does. That is why a really short runner intake like one for a carb doesn't totally destroy low rpm power.
Old Apr 1, 2017 | 08:02 PM
Conanski's Avatar
Conanski
It is an early version, I thought the 5.0 and 5.8 lettering started in '89 but I could be wrong on that.
Old Apr 1, 2017 | 10:21 PM
GuyinWy's Avatar
GuyinWy
I think it is an '86, but don't recall for sure. I found another intake first, but it was broken at the center hole on the inside.
So an aftermarket would be an improvement over the 5.0/5.8 combo then. How would something like the Typhoon compare to the Truck Performer?
Old Apr 1, 2017 | 10:29 PM
Conanski's Avatar
Conanski
Yes
Its the same lower portion, the Eddy truck upper has super long runners.. 3-4" longer than stock so it's tuned to lower rpms... purposely designed to enhance the powerband of a stock motor from 0-3500rpm.
Old Apr 1, 2017 | 10:33 PM
GuyinWy's Avatar
GuyinWy
Dangit. I was hoping there was a less expensive option, but if the Truck Performer is the best choice for a tow rig/ torque project then I guess I'll wait a bit and pick one up.
Old Apr 1, 2017 | 10:50 PM
Armytruckchuck's Avatar
Armytruckchuck
my 85 was like that intake plus had v belt my 87 had the 5.0 stamp serpentine belt
never had an 86 but i figured they would be like the 85 and upgraded in 87
way off subject but does 86 have v belt or serpentine?
BaronVonAutomatc
29
Oct 1, 2022 10:23 AM
HotrodSmurf
Dec 10, 2010 05:20 AM
ckcn10
23
Jun 15, 2007 02:08 AM
coplin
Mar 20, 2007 11:21 PM
Da Mother Ship
Aug 21, 2004 08:33 PM
