OTC Universal Breakout Box Instructions?
Old Aug 15, 2010 | 04:11 PM
WoodHeat's Avatar
WoodHeat
Question OTC Universal Breakout Box Instructions?
I just got one of those OTC 80 pin 3226 breakout boxes. The pins are not numbered though. Does anyone have a pdf instruction manual for it? I asked OTC but they said they no longer have it because it isn't being made any more.
What about the pins numbering...do they start at the top with 1>2>3...going left to right...up or down...start at the bottom and go up?
Why OTC wouldn't put that information on the box itself seems short sighted for a highly expensive tool.
Old Aug 15, 2010 | 08:54 PM
Franklin2's Avatar
Franklin2
I suppose you have to look at what it's plugged into before you can decide pin numbers. The computer would give you the numbers correct?
Old Aug 16, 2010 | 12:52 AM
WoodHeat's Avatar
WoodHeat
Well, yes, the computer's connector has the pin numbers on it. The issue is that it connects to the box via a 60 pin EEC IV adapter while the box is a native 80 pin one.
I tried a continuity test between the knock sensor wire (goes to pin 23) and the box but didn't get a tone even after moving the probe to each hole. Will these boxes allow a continuity test or is there too much wire between the connections for that?
Old Aug 16, 2010 | 03:52 AM
WoodHeat's Avatar
WoodHeat
Figured it out.
I took it apart and the circuit board showed the test point numbers. It starts in the top left with test point 1 and goes to the right thru 8. Next row is 9 thru 16 etc.
It's good I took it apart because I found tp 1's trace on the board was burned apart at some point. Repair time.
Ju1cE
2004 - 2008 F150
Jul 1, 2017 10:52 AM
JockD
Oct 6, 2015 11:35 AM
Leroy Axe
2004 - 2008 F150
Sep 17, 2015 07:43 PM
AlaFordF15o
Garage & Workshop
Jan 5, 2014 06:44 PM
hayseedscout
Mar 8, 2012 11:21 PM
