oil cooler parts checklist
getting oil cooler replaced next weekend. here is a list of parts that i have order now. i am trying to get input on stuff i need to have checked and replaced while intake is off.
oil cooler assembly kit(ford)2003 - 2007 6.0 FORD Diesel Oil Cooler Master Kit: eBay Motors (item 360289662150 end time Sep-11-10 07:26:42 PDT)
EGR block off kit(from ford)03-07 6.0 POWERSTROKE FORD EGR COOLER BLOCK OFF KIT: eBay Motors (item 360288217672 end time Sep-06-10 15:50:22 PDT)
updated turbo tubes (ford)Ford Diesel 6.0 BETTER TURBO OIL FEED &DRAIN TUBE 03-07: eBay Motors (item 190429804015 end time Sep-09-10 18:51:20 PDT)
antifreeze
engine oil
clean egr valve
check turbo for sticking vanes
new thermostat
new serpentine belt
cooling system flush VC-9, already done this going to fill and flush everyday this week.
diesel site coolant filter arriving tuesday install wednsday
anything else?
truck is running fine except this 30 degree difference between EOT and ECT.
have edge insight installed and running. was going to try to get the egt probe in but i am putting that off for a month since i have decided to repair this oil cooler.
antifreeze
engine oil
clean egr valve
new thermostat
new serpentine belt
anything else?
on
ok. Fisrt off you are buying an oil cooler kit. for basicly list price. that comes with a free oil filter.
egr block off kit you have linked a) is not a ford Item as ford will not sell any such item
you are about to pay 145 for a intake gasket set and a freeze plug. Not a good deal.
drain and supply tubes look about right.
first off i really value yours and bismics opinions and advise on this board , so ok the oil cooler kit as you said comes with a oil fliter and the ipr screen. for list price it was one of the cheapest on ebay. i priced this at the ford guy that is here on his site and it listed for over three hundred without the screen or the filter. as far as the block off kit yes i am probably getting ripped with the price but it is supposed to have all the intake and egr o rings and gaskets and the turbo hardware kit. i really do not want to fight over the prices different people have for these parts. i looked at a lot of sites and did a lot of price searches and this is what i came up with i only have around 18 hours to do this repair starting on a saturday, has to be running to drive to work by 6 pm sunday night. no dealer parts counters within 50 miles are even open on saturdays, and only a couple of diffrent auto parts stores none of which keep these things in stock, i finially ordered the diesel site filter system after trying to find all the parts locally for 2 weeks the guys at the parts counters around here couldn't even find the filters let alone a base for them to go on. so i am trying to make sure i have all the orings and gaskets i need to do this job. so what i am really wanting to know is does this look like it has all the orings and gaskets i will need since i am trying not to reuse any old ones? also is there any minor things i need to look for while i have it apart?
thanks, i was hoping it was. i have been researching this repair and how to do it for awhile now. my wife was really glad to hear that i am done spending money for now. at least this truck isn't nickel and dimeing me for repairs................ its a hundred or two at a time but maybe after this repair it will get better.
In my opinion, unless you have had trouble with the turbo, I wouldn't crack it open. Given the time constraint you'll be under, you'll be doing everything to you to meet your deadline anyways without messing with the turbo. You can always come in later and pull the turbo and clean it which will require a whole other kit for cleaning it, etc.
The cooler rebuild won't be 20 minutes if its dirty like mine and you want to clean it, etc. So plan on a good hour'ish for it from start to finish.
You using a service manual for the assembly/disassembly?
The service manuals are invaluable but if you get into a pinch or need ALL the related data for removing/replacing the different related components such as turbo, intake, etc. then check out www.alldatadiy.com
For $29.95 you can get the whole service manual online. It is the Ford service manual too....so well worth the money! Problem is you have to have access to internet close to vehicle...unlike my greasy book!
well its done. i got lucky really and found a guy here that is a ford diesel tech that was willing to do the whole job today during his off hours. all i had to do was drop off the parts and the truck. so new oil cooler installed, egr cooler blocked off, new thermostat, new belt, fresh coolant flushed again that is the 15th time in a week, new coolant filter installed thanks to dieselsite, fresh oil and a new ipr screen.
So my ECT/EOT temp differential was 32 to 35 degrees. now its is about 6-8 degrees and i keep a coolant temp at a even 192 degrees instead of 176 to 185. my old thermo was stuck open a little i think. so now i just need to hook to something heavy and see how it pulls. thnask to everyone here that has provided all this excellent information and advice.
no on to the next fix, tie rod ends
Walston
13
02-19-2008 08:32 PM
biz4two
03-17-2004 09:48 PM
gtex
03-03-2003 01:08 AM
