Even more axle decoding questions
Old Feb 15, 2003 | 12:36 PM
Maitland's Avatar
Maitland
I'm pretty sure I know what axle I have, but I just wanted to confirm.
The tag on my axle is as follows:
WFE BA 0K16
2L75 9 S3158
I know the 2L75 9 part is right, but the rest of the numbers and letters on the first and second line are a bit hard to read, so they may not be right. The BA could be a B4, and the S3158 could be a 53158.
I read all through this forum, and on some other sites, and as far as I can tell the above code means I have a limited slip axle with a ratio of 2.75. The axle itself looks to be a 9", which I think the 9 in the above code refers to. The axle code on the door jam sticker says H3, but I haven't been able to find out if that matches the tag on the axle.
The truck is an '81 F-150, 300 I6, and a C6. And if the axle ratio is 2.75 then I'm even more amazed that the truck accelerates as fast as it does!
Anyway, I appreciate any help you can give me with this.
Old Feb 15, 2003 | 01:47 PM
87black150's Avatar
87black150
I don't think you need any help. You already figured it out. You have a Ford 9" 2.75 ratio Limited Slip. And yes the H3 code matches.
OneLostCowboy
1978 - 1996 Big Bronco
Aug 22, 2016 08:06 PM
64M100builder
Aug 7, 2016 11:02 AM
carguy94
1983 - 2012 Ranger & B-Series
Oct 8, 2015 06:32 PM
Tegetus
Jun 21, 2010 08:26 PM
branpollard
Dec 26, 2004 03:43 PM
