Sponsored by: Auxito
Weird Problem
Old Aug 14, 2010 | 08:28 PM
lockdoc72's Avatar
lockdoc72
Weird Problem
I recently purchased a 1999 F-150 5.4 gas/CNG. The truck is 1, extremely hard to start. 2, It idles rough all the time. The mechanic I bought it from worked on and couldn't fix it and the local dealer gave up. While testing I unhooked the egr and a couple of other sensors and didn't get a trouble. Alittle help please.
Thanks
Lockdoc
Old Aug 15, 2010 | 02:34 PM
Bluegrass 7's Avatar
Bluegrass 7
First some comment.
If you didn't need an engine with this dual fuel option, it would have been much less expensive to keep repaired.
What you have a is "very complex" seperate fuel systems arrangment.
It takes a shop familuar with and service info to even begin to address any issue in depth.
There might be codes set to indcate a probable system issue. This is where you start to chase the problem, otherwise a discovery search must be done from service info..
You have no solid info to work with for the moment.
Is it hard starting on gas, NG or both as a starting point.
What does the PCM read for codes and was a good scanner used to take a look at the system once it was running?
I remember an owner in England that bought one and could not get any service on it.
The shop needs to get into a service source on Bi FUEL engines, then into diagnostics and symptoms section, to begin the quest to solve the issue.
There are a number of areas to be looked at.
This is all from referencing my service data disc section on these engine options.
It's far too much data to type out here and be understood.
I wish you good luck, at the least.
Old Aug 15, 2010 | 04:24 PM
lockdoc72's Avatar
lockdoc72
Here is what I was told - the truck was owned by Piedmont Natural Gas. It went to auction. It was used as a service truck up until 6 mos ago. it has 47k on it. The #3 plug blew out. The entire head and cop was replaced. The only code it show is a lean code. THe service or check engine light is not on. There is NO CNG in the truck. When we pulled some of the vac lines and plugs (EGR, etc) no code was created. Thanks
Old Aug 15, 2010 | 06:49 PM
Bluegrass 7
Need to know what the code is first.
A code set will light a CEL lamp unless it is burnt out.
If it is a code suggesting an A/F ratio issue, the motor has a good chance of acting the way you discribe.
Don't be concerned about checking for a lamp/code response by disconnecting parts.
Address the code in memory first.
Your problem may not turn out to be that difficult, then you would be lucky.
Owners try to word to death the problems and disreguard the codes.
We live or die by codes because it's most often the only way we know what is or is not happening within a complex computer controlled system.
This is why there are more than 1000 codes in the program, to help id issues.
Old Aug 15, 2010 | 07:13 PM
Podaso's Avatar
Podaso
Quick question...how come you purchased a truck with problems that both a mechanic and the dealership couldn't figure out?
Old Aug 16, 2010 | 12:14 AM
Lime1GT's Avatar
Lime1GT
Did you check the TSB's from this site? Here's one that might apply; *03-10-2***DRIVEABILITY - COMPRESSED NATURAL GAS (CNG) - ROUGH IDLE OR NO START WHEN COLD - VEHICLES EQUIPPED WITH CNG BI-FUEL ENGINE ONLY.
There are more regarding gas/cng vehicles.
Old Aug 16, 2010 | 06:28 AM
lockdoc72's Avatar
lockdoc72
Thanks Bluegrass7. I'll pull the codes and get back to you.
Old Aug 16, 2010 | 03:22 PM
Nightmare97's Avatar
Nightmare97
It sounds like you're saying it's hard starting when running regular gas through it, correct? I'd be wondering about fuel pressure if so. Here's an ugly thought. I'm not up on these CNG trucks, but I'll assume they have two fuel tanks, if regular gas sat in the system for a long time and varnished there could be a restriction anywhere. I'm thinking this is real possible because it was a natural gas company truck.
ATX F250
6.4L Power Stroke Diesel
Apr 8, 2012 01:33 PM
falconqueenD
Ontario Chapter
Aug 4, 2010 03:54 PM
VintageRR
Aug 20, 2004 12:14 AM
moore1960
Oct 31, 2002 08:12 AM
pendentive
Aug 22, 2002 07:42 AM
