off topic
Old Aug 15, 2010 | 10:14 AM
52 F3's Avatar
52 F3
Originally Posted by fifty-two_f1
The only thing I have not done to it is advance the timing. I am lost.
I would sure check the timing.
Slow timing will definitely make it ron hot.
Can you find out what the total timing should be at load and check that?
If it has an advance the initial timing could be set right but not advancing.
Old Aug 15, 2010 | 10:17 AM
fifty-two_f1's Avatar
fifty-two_f1
It has no advance, and I advanced it until it kicked on the starter then backed off a little bit.
Old Aug 15, 2010 | 11:08 AM
52 F3's Avatar
52 F3
Are you sure there is not a mechanical advance in the base of the dist.
A set of weights under the plate the points set on.
Old Aug 15, 2010 | 12:23 PM
fifty-two_f1
Well, I will have to look again, but I think i figured it out.. There is a valve on the inside of the compressor that was open and letting a lot of air out. I think it is there to bleed the pressure off before you shut it off. I shut it and it built pressure quicker and ran slower. It ran 220-225 the whole time and was not boiling over. That is a little warm for my liking, but it is 95 degrees here. Thanks for all the help!!
Old Aug 15, 2010 | 06:32 PM
fixnair's Avatar
fixnair
Sure sounds like combustion gasses getting into the cooling system. Could be a cracked head or block.
Old Aug 15, 2010 | 07:49 PM
sdetweil's Avatar
sdetweil
ah, you had the dump valve open, so it was running full clutch the whole time!!..
that'll do it..
Sam
Old Aug 15, 2010 | 07:55 PM
fixnair's Avatar
fixnair
I don't think that will cause overheating. That compressor is designed to run wide open all day w/o overheating. There is still something wrong and since combustion gasses in radiator is the only thing we havn't checked I'll bet thats it.
Old Aug 16, 2010 | 01:58 PM
reg1952's Avatar
reg1952
Is the T stat still in the engine? With a T stat removed it can run hot or even overheat.The coolant travels to fast through the block and can not pick up any heat.It also travel through the rad to fast and can not get rid of the heat.
Old Aug 16, 2010 | 02:15 PM
Old F1's Avatar
Old F1
So now that you have it so that it won’t boil, I would put some tape over the temp gauge glass.
Old Aug 16, 2010 | 04:48 PM
rbig1's Avatar
rbig1
well do you have the unit sitting level when running. they will shoot fire out the hose and die if it isnt level gets very expensive pluss having to find parts just past experience. i didnt like it
Old Aug 16, 2010 | 08:51 PM
fifty-two_f1
that'll do it..
Sam
Yea, I felt stupid, but I was so happy to figure it out!! I do have it setting level, and the thermostat is out of it. Also it was probably running 220 ish because it was 95 degrees here and its blowing hot air from the oil cooler through it.
Old Aug 16, 2010 | 08:52 PM
sdetweil's Avatar
sdetweil
at least its explainable.. I HATE the problems that come & go.. (and don't stay away!)
Sam
ma115
Jun 4, 2014 09:50 PM
6686L
Jun 23, 2008 11:24 AM
blindlightguy
Mar 8, 2008 10:14 AM
DeathMobile
Apr 28, 2005 12:38 PM
1stFordTruck
Jan 27, 2002 06:22 PM
