BRAKE PAD RECOMENDATION'S
Old Aug 13, 2010 | 09:05 PM
MP7pt3's Avatar
MP7pt3
Ok just my luck getting ready to go on vacation & my brakes start grinding. So my question is since i don't have time to wait on the Hawk pads & slotted rotors that i would like to do. What other pads would you guys recomend ?
Old Aug 13, 2010 | 09:18 PM
Shake-N-Bake's Avatar
Shake-N-Bake
I have been satisfied with the Motorcraft pads. I tried the NAPA brand one time and they didn't last nearly as long as the OEM pads.
I don't turn my rotors either. I just check to make sure they are flat, slap on the new pads and keep on motoring.
So far so good. 253k miles and counting.
Quick444's Avatar
Quick444
I just bought some HPS Hawk pads front & rear from Riffraff. I should have them on in the next week or two and will be happy to chime in.
Old Aug 13, 2010 | 09:51 PM
EpSiloN's Avatar
EpSiloN
OEM the only way to go
Old Aug 13, 2010 | 10:20 PM
MP7pt3's Avatar
MP7pt3
what about EBC any body tried them ?
Old Aug 14, 2010 | 10:06 AM
MP7pt3's Avatar
MP7pt3
anyone else
Old Aug 14, 2010 | 11:02 AM
Supercab's Avatar
Supercab
If you are on a time concern, I'd just throw on a set of what ever your parts store has-better than metal to metal and destroying your rotors!
Then get whatever you want & may be turn the rotors when you have time.
Old Aug 14, 2010 | 01:52 PM
WA.Ranger's Avatar
WA.Ranger
I believe Milleroutdoors has a set of the "Yellow Stuff" on the front axle of his rig. I have Hawks on the front of mine, wanted a set of Yellow Stuff's for the rear, but will have Green Stuff's instead........Ebay.....$2.99!
Old Aug 14, 2010 | 02:09 PM
MP7pt3's Avatar
MP7pt3
thanks for the input guys i went with a set of oriley ceramic supposed to be the same as wagners. the only reason i did that is i am monitoring another thread about doing a MOD to 2005 calipers & rotors & plobably do the cryo rotors & hawk pads then.
Old Aug 14, 2010 | 04:54 PM
spdmpo's Avatar
spdmpo
I haven't tried them all but out of the OE, Napa, and Hawk, the EBC Yellowstuff pads are hands down the best. They do make some dust though.
Old Aug 14, 2010 | 07:46 PM
milleroutdoors's Avatar
milleroutdoors
I have the ebc yellowstuffs on the front, soon on the back. 6600 mile road trip confirmed my decision. Dust is similar to oem( for me). I had to order them and it took a few days to get, so time frame wise, you probably made the right choice. I am trying to convince Clay to carry the ebc line,
Old Aug 15, 2010 | 06:43 AM
spdmpo's Avatar
spdmpo
Do yourself afavor and don't get hawk pads.
Old Aug 15, 2010 | 08:35 AM
megawatt00's Avatar
megawatt00
Why cant they make a good reasonably priced pad that does not make a ton of dust??
Old Aug 15, 2010 | 08:37 AM
Izzy351's Avatar
Izzy351
They work quite well for me. MUST be broken in correctly though.....
Old Aug 16, 2010 | 08:43 AM
Fandini's Avatar
Fandini
Where do you get EBC yellow stuff pads? What is the difference between the Yellow stuff and green pads? Are they that much better than the OEM pads?
