Stuck in Butte, Montana
P040D Exhaust Gas Recirculation Temperature (EGRT) Sensor A Circuit High
P1000
These are the codes I am getting on my buddy's 08 F350. We are on vacation and we had trouble with his truck going into regen mode all the time, for the last two days.
He has had trouble before with the DPF plugging and has had it replaced once already.
The truck was completely stock yesterday, and it went into a limp mode and would not accelerate. He was pulling a 5th wheel weighing about 13000 lbs. Anyway we were lucky enough to "breakdown" near Livingston
Montana and went in to see Steel at GOS.
Last night we installed a 4 inch exhaust system and an EDGE CTS while drinking beer in the campground. Anyway there were no codes last night and we made it to Butte today with the trailers. Then the codes above started popping up and it has no power. It also tried to regen "cleaning exhaust filter" even though we programmed in with the CTS that there is no DPF to be cleaned. The Exhaust is 4 inch Flo Pro from the down pipe back. Cat and DPF removed.
Can anybody help us troubleshoot?<!-- GAL --> <TABLE border=0 cellSpacing=0 cellPadding=0 width=400><TBODY><TR><TD height=5 width=5></TD><TD style="BACKGROUND: url(http://thedieselgarage.com/forums/images/misc/forumbox_top_tile.gif)" height=5></TD><TD height=5 width=6></TD></TR><TR><TD style="BACKGROUND: url(http://thedieselgarage.com/forums/images/misc/forumbox_left_tile.gif)" width=5></TD><TD class=forumbox><TABLE class=alt1 border=0 cellSpacing=1 cellPadding=6 width="100%"><TBODY><TR><TD class=tcat align=left>GOS Performance </TD></TR><TR><TD style="BACKGROUND: #ffffff; COLOR: #000000" align=left>******** onmouseover=GAL_keepopen(); onmouseout=GAL_hidepopup(); height=450 src="http://www.gosperformance.com/" width="100%">Your browser doesnt show Iframes!*********>
</TD></TR></TBODY></TABLE></TD><TD style="BACKGROUND: url(http://thedieselgarage.com/forums/images/misc/forumbox_right_tile.gif)" width=6></TD></TR><TR><TD height=6 width=5></TD><TD style="BACKGROUND: url(http://thedieselgarage.com/forums/images/misc/forumbox_bottom_tile.gif)" height=6></TD><TD height=6 width=6></TD></TR></TBODY></TABLE>
******** type=text/javascript>gal_register('gal_12_1019131', '1', '1', '0', '0', '0');*********>
<!-- / message --><!-- sig -->
P1000
P1000, just ignore:
P1000 RESET OBD Systems Readiness
Test Not Complete
This error occurs when all other DTC’s have been
erased from the system. This error will subside
when all OBD monitors have been completed.
P040D:
P040D X X X
Temperature Sensor
A Circuit High
This error occurs when the EGR cooler inlet sensor
temperature output value is lower (higher voltage
signal) than a minimum probable temperature,
indicating an open circuit or short to power.
N > 650 rpm
torque setpoint >53 N-m
ECT > 60 deg C
4.65v >5sec
Wiring, Tegr_IN sensor, PCM
Most likely it is the sensor itself.
Look at the sensor right off of the valve.
Test Not Complete
P040D:
P040D X X X
Temperature Sensor
A Circuit High
N > 650 rpm
ECT > 60 deg C
4.65v >5sec
Try here, you should be able to locate it
http://www.backglass.org/duncan/ps64...4_overview.pdf
All fixed up and back home in Alberta. Turns out that the pyro in the passenger side up pipe was the culprit. We picked up the necessary replacement at the Ford dealer in Butte and put it in the truck after the wives and kids went to sleep. 1 am Sunday morning we had her up and running like a champ.
fastman35
13
11-27-2016 09:24 PM
ROBBINthaHOOD
08-20-2012 07:17 PM
