Carb. question
Old Aug 13, 2010 | 07:57 PM
merccougar93's Avatar
merccougar93
Carb. question
I have a 74 f100 302 with a edelbrock 650 carb and intake. It will start up fine but if i try to give it gas, it will die. It will run if i barely touch the throttle, but if i go any further is when it dies. I took the air cleaner off and sprayed some carb cleaner in it and ran it for a few minutes and no change. It sounds like it is sucking more air than fuel. I tried adjusting my idle screws to no avail. I dont know a whole lot about carbs and i was wondering if it was a problem with the carb, fuel pump or filter. The plug wires were changed along with the distributor cap and rotor button. Plugs were not changed(parts guy gave me the wrong thread size) points have not been changed yet, but are in need of it. Is there anything else i can check to help?
Old Aug 13, 2010 | 08:31 PM
supercabfreak's Avatar
supercabfreak
id say fuel pump is first place to trouble shoot....and its not imposible to get a new pump that doesnt work these days. 2nd check and or replace all your fuel filters and turn it over with the preshure side of the pump disconected from the carb and see if your getting a nice solid stream of fuel.
Old Aug 13, 2010 | 08:35 PM
merccougar93
ok, thanks for the quick response
Old Aug 13, 2010 | 10:41 PM
fmc400's Avatar
fmc400
MSEE
Sounds like a vacuum leak or faulty accelerator pump.
Old Aug 14, 2010 | 08:24 AM
Tees77f150's Avatar
Tees77f150
Were I would look also. My carb was in serious need of an accelerator pump. Would fire up and idle nice, but give it ANY gas, and it spit sputtered and stumbled on it face till you let off of the gas. However, a vacuum leak can produce similar symptoms, and could be a real easy fix too.
Old Aug 15, 2010 | 11:07 AM
merccougar93
ok, checked the fuel pump. it would shoot a big squirt of fuel out at start up, then nothing. So i changed the fuel pump, changed and adjusted the points, and changed the spark plugs. Now she wont fire over at all. it will start up with carb cleaner. It is getting sufficcient fuel to the carb at the lines. Is the accelerator pump on top of the carb beside the barrell?
ok. after a little while the truck has started up and runs good at idle, but again with touching the gas just a little bit it starts to die out for a second, then it revs up, but its not running 100%. Its real sluggish and doesnt have a lot of power. Have decided that a carb. rebuild would be the best thing, finding trash in the fuel when i removed the fuel line to check fuel pressure.
Old Aug 15, 2010 | 03:49 PM
pro70golfer14's Avatar
pro70golfer14
my truck did that same thing off of idle.
Then i looked and i had my vacuum advance hooked to manifold vacuum and not carb.
Swapped them out and now its good.
Old Aug 15, 2010 | 04:32 PM
supercabfreak
true the vacume advance is what advaces or retards the spark timeing i totaly forgot!
Old Aug 15, 2010 | 05:14 PM
merccougar93
the vacuum advance is hooked to the carb. Im not sure if its good or not.
Old Aug 15, 2010 | 10:54 PM
fmc400's Avatar
fmc400
MSEE
The accelerator pump is on the front of the carburetor. Have you checked for vacuum leaks?
Old Aug 16, 2010 | 09:24 AM
merccougar93
yes. forgot to mention i did not find any. but thats what i thought about the acc. pump.
Old Aug 16, 2010 | 10:56 AM
Aaron-71's Avatar
Aaron-71
I would have to say that the problem would probably lie with your accelerator pump.
I'm re-doing the carb on my 351W right now. It's just a simple 2100 Autolite carb.
The accelerator pump diaphram on your carb is probably toast... I know mine was (ripped, torn, rusted, and not very manuerverable).
My accelerator pump wasn't even pumping anything into the throat of my carb because it was so gunked up and beaten.
If I were you, I'd just rebuild my carb. It'll take maybe 2-3 days if you're fast (less if you have a faster acting de-greaser/cleaning prodcut).
The carb kit I bought cost me a whole whopping $31.24. It's worth every penny to get my truck running right again.
Old Aug 16, 2010 | 01:10 PM
merccougar93
yeah, i thought i mentioned before i was going to rebuild the carb., but i have a wondering mind sometimes.. so i might not have, but im in the middle the carb rebuild- had to stop for a little bit now, it started to rain. but the accelerator pump operated fine and i saw no signs of a problem with it, spring was good, rubber gasket or seal in it was in good shape, but there was a tremendous amount of trash in the carb. So right now im thinkin im gonna end up flushing the gas tank out. I do have a good cleaner, i cant think of the name of it off hand, but it works in about 30 min. It didnt get all the dirt burned on the surface of, but its not my carb, i was told dont worry about it. but it did clean it up pretty good, it got all of the gunk out from inside, made it look like brand new. But thanks for the help guys, it might have also had a little vacuum leak cause the bolts to the manifold werent tight at all, but my carb cleaner test didnt show anything with that, but that dont mean it didnt have a vacuum leak there.
Old Aug 17, 2010 | 09:14 AM
merccougar93
its all done now. i spent more time fiddlin with the accelerator linkage gettin them to work right than i did rebuilding the damn thing. runs like a champ now
Old Aug 17, 2010 | 09:42 AM
Aaron-71's Avatar
Aaron-71
Nice. Great to hear that it all worked out for you. I've yet to finish mine, but it's coming along nicely.
I'm not in too much of a hurry, but yet I am haha.
