Pully
Old Aug 13, 2010 | 01:20 AM
Rick Wallace's Avatar
Rick Wallace
Pully
When I go to take off the bottom pully {on the crankshaft} will a harmonic balacer puller work? Ive had it for years but never used it.
Old Aug 13, 2010 | 01:44 AM
oreocreaming's Avatar
oreocreaming
yes it will. just make sure you leave the bolt in the middle so you dont collapse the first couple threads with the center rod. if you do, then you will have to tap the crank again
Old Aug 13, 2010 | 11:38 AM
87crewdually's Avatar
87crewdually
If all your taking off is the pulley, it just unbolts from the balancer, no puller necessary. The balancer on the other hand you'll need a puller.
Old Aug 13, 2010 | 12:30 PM
Rick Wallace
I meant take it all off, So I leave the bolt in?? or loosen it ? My goal today is get the front cover off and have a look Forgive me for being ignorant,this is my first time !
Old Aug 13, 2010 | 01:05 PM
oreocreaming
keep the bolt in about 3 or 4 threads. By the time the hermonic ballancer backs off enough, it shoyld be loose enough to tap off with a rubber mallet.
Old Aug 13, 2010 | 01:08 PM
oreocreaming
you pull then engine yet or still doin it inside the engine bay? If you pulled it... You might as well throw a new oil pump and pan gasket. Preventive maitnance is key. I wish I would have done mine but I didn't plan on keeping this engine in for long.
Old Aug 13, 2010 | 01:13 PM
Rick Wallace
OK, Got it,thats what I thought,just wanted to be sure. Its still in the truck for now,I have the clip out ,got it all ready to pull,still saving funds for engine stand,chain hoist,parts,beer,bandaids,,you know,things like that.....Yes its getting new everything when I get to that point.
Old Aug 13, 2010 | 04:35 PM
Rick Wallace
Got it off, the last time the truck ran,I had that awful chirping noise I kept talking about,coming from the front of the engine.I can turn the engine with a ratchet and get that noise from the camshaft gear.should it have any play in the camshaft at all? I can move it forwards and backwards and side to side. Bearings bad? and how does the cam come out?
Old Aug 13, 2010 | 07:38 PM
Rick Wallace
Before I forget,is there anyway to test the lifters? And should I store them in oil or just like they came out?
Old Aug 13, 2010 | 07:51 PM
Otahyoni's Avatar
Otahyoni
I've never had the cam out of a diesel, but if it's the same as a gasser, you pull all of the lifters and pushrods, check behind the gear for a retainer (and remove it if there is one) and it should slide out.
If you're not replacing the bearings, be VERY careful you don't scratch them with a cam lobe. They are very soft.
I don't know how to replace the bearings. I've never done it...
As far as play, moving fore and aft is ok (to an extent) but it shouldn't move noticably up/down/sideways at all...
Old Aug 13, 2010 | 07:52 PM
Otahyoni's Avatar
Otahyoni
I would store them in numbered plastic baggies. Make sure that each one returns to where it came from.
Old Aug 13, 2010 | 07:56 PM
Rick Wallace
oops...to late for that..........
Old Aug 13, 2010 | 07:59 PM
oreocreaming
you press bearings in and out $50 is the average cost to have a machine shop do it. Agree about numbering them. Even they are roller lifters, there's still matched wear for each. No need to store them in oil but you should soak them for 24 hours before installing. Better to be safe then sorry. And there's 2 or 3 bolts behind the cam gear that retains it in place. Just rotate it for the opening to expose them
Old Aug 13, 2010 | 08:02 PM
Otahyoni's Avatar
Otahyoni
It shouldn't be too bad. They will have to wear into a new pattern...
According to my Chilton's manual, the bearing journal clearance should be .001-.005" and the end play .001-.009".
1/16" = .0625 so if it moves noticeably, the bearings are probably worn out.
Old Aug 13, 2010 | 08:27 PM
Rick Wallace
Its got at least 1/8 inch of play in all directions
