Pully
Old Aug 13, 2010 | 08:44 PM
Otahyoni's Avatar
Otahyoni
I'd say you need new bearings at minimum... Hopefully it hasnt damaged the block.
If you have a micrometer, the Bearing journal diameter should be: 2.0990-2.1000 on all 5.
Might want to check that to see if the cam is damaged.
If you need a new one, typ4 has that "torque cam" that's been talked about.
Old Aug 13, 2010 | 08:53 PM
Rick Wallace's Avatar
Rick Wallace
Its going to the machine shop anyway,I just wanted an idea before it went
