A couple intercooler install questions???
Old Aug 12, 2010 | 09:00 PM
plgebbia's Avatar
plgebbia
I started installing the intercooler today and have a couple questions,
1. Do I need to get a SD style powersteering line to clear the hot side pipe?
2. What is the best way to seal the two boost line ports on the spyder?
3. Will I be able to connect the cold side pipe with no mods except a longer(6+in) boot?
Thanks!
Old Aug 12, 2010 | 09:10 PM
oldbird1965's Avatar
oldbird1965
1. I didn't need a new SD PS line.
2. Mine didn't have two boost lines??
3. I got my pipes from a 99 and had to use a 2 1/2 inch insert between the double boots.
Old Aug 12, 2010 | 09:14 PM
ccarrier's Avatar
ccarrier
pics please
Old Aug 12, 2010 | 09:16 PM
plgebbia's Avatar
plgebbia
Thanks for answering,
What did you do to work around the PS line?
This one has two ports on the spyder, one for the map and one for the wastegate, I just want to plug/delete both and wondered how other people had done it.
Old Aug 13, 2010 | 06:44 AM
427 fordman's Avatar
427 fordman
I plugged mine with jb weld. No problems as of now. Cold side is the pass. side and I had to cut and weld a couple together to get to my spyder. The drivers side I just lengthened the pipe 4-5 inches just off the spyder a little bit. I'll be working on my truck a little today and I'll take a couple pics for you (if I remember)
Old Aug 13, 2010 | 07:28 AM
Fullcrew7.3's Avatar
Fullcrew7.3
I tapped the 2 holes and then used some locktite and a couple little bolts. As for the tubes, I got the cold side cut and welded and added and elbow at the bottom. Really depends on how you want to route it. PS line? I just manually adjusted it routing.
Old Aug 13, 2010 | 08:54 AM
oldbird1965
Originally Posted by ccarrier
pics please
https://www.ford-trucks.com/forums/9...ml#post8870745
Old Aug 13, 2010 | 09:14 AM
Neal 97 250's Avatar
Neal 97 250
The PS line on mine was in the way too. The line will just rotate in the fitting so I just rotated it out of the way. IIRC it now lays on the inner fender. I wrapped it with some heavy plastic hose protevtant just to keep it from wearing.
Old Aug 13, 2010 | 11:35 AM
plgebbia's Avatar
plgebbia
Thanks for the info and pics, I think I am going to have a couple inches added to both my pipes (they are both steel) and I think they will work nicely.
When I get the money I will order a set of boots from Riffraff.
Lhornung
115
Mar 19, 2017 08:51 PM
kthemurphy
Sep 18, 2016 02:51 PM
bnine
15
Apr 1, 2008 10:25 AM
MikeFromShiloh
Dec 8, 2007 06:26 PM
powerstroke1869
Aug 26, 2007 07:15 PM
