Lower Ball Joint replacement
Old Aug 12, 2010 | 07:37 PM
quisp's Avatar
quisp
'88 f150 4x4 lariat 5.0
Can I Get away with replacing the Driverside Lower Ball joint without removing, or replacing the Upper Balljoint?
Old Aug 12, 2010 | 07:42 PM
96ford250's Avatar
96ford250
you might as well do both while your there can save you lots of time later down the road.
Old Aug 12, 2010 | 07:54 PM
ac700wildcat's Avatar
ac700wildcat
I agree, you may as well do both. I used a ball joint press to do mine and they both have to come out anyways, otherwise you can't use the press.
Old Aug 16, 2010 | 09:33 AM
quisp's Avatar
quisp
I guess theres no getting around the upper baljoint then, I was avoiding it because of the rust, its still goood, but I guess your both right on this-gonna change them both.
-thanks
bchez
2004 - 2008 F150
May 7, 2014 02:07 AM
labman1014
Sep 21, 2010 08:22 PM
peter p
1997 - 2003 F150
Sep 2, 2009 07:04 PM
jimwesselman
1997 - 2003 F150
Apr 16, 2008 02:56 PM
MitchPeters
Jul 7, 2004 09:45 AM
