95 7.3
Old Aug 12, 2010 | 05:56 PM
zach350ford's Avatar
zach350ford
im thinking about rebuilding the engine in my f-350 soon its a 7.3 powerstroke with 326xxx on it now iv done gas motors be for how hard of a in-frame rebuild is it and what are some helpful tips on doing it?
Old Aug 12, 2010 | 06:59 PM
plgebbia's Avatar
plgebbia
I believe you have to pull the motor before you can rebuild it. Someone else should have info on rebuilding it.
Old Aug 12, 2010 | 07:34 PM
rideracelivemx7's Avatar
rideracelivemx7
due to the nature of the cross member it is difficult to do an inframe rebuild. if you want to pull your motor mounts and jack up the motor as much as possible then you can get the pan off just enough, but still that is just a pain, i would suggest just pulling the motor and save your self a few bloody knuckles and cuss words!
Old Aug 13, 2010 | 10:55 AM
Brown Falcon's Avatar
Brown Falcon
Some have cut the crossmember out and then welded it back into place when they were done. I'd say that's the only other way to do it besides pulling the engine.
Old Aug 13, 2010 | 11:12 AM
RRranch's Avatar
RRranch
Pull it and do it right. Never cut that crossmember. Diesels are no harder thana gas engine to rebuild. Just a couple different parts in there like injector cups and a lot of o rings but it's easy.
aussie_f350
Jul 29, 2012 05:43 AM
dmanshane
Dec 26, 2011 11:15 PM
Aune163rd
18
Jan 15, 2011 05:58 PM
gofalls
May 10, 2010 09:52 PM
iakobos
36
Dec 28, 2008 04:41 PM
