Need Help Rebuilding 7.3
Old Oct 25, 2008 | 07:01 PM
iakobos's Avatar
iakobos
My father owns a 2000 F350 that dropped a valve and now, due to limited funds, he's in the process of doing the rebuild himself. All the machine work is finished and he has the rotating assembly together.
Now he's trying to figure out if he has the camshaft and crankshaft timed right. What he really needs, and would buy if he could find it, is an assembly manual. However, rebuilding a 7.3 must be a trade secret because I can't find one anywhere.
Any help would be greatly appreciated.
Old Oct 25, 2008 | 07:35 PM
F350-6's Avatar
F350-6
Welcome to FTE. Tell your Dad not to be shy about logging in and asking questions.
Here's a copy of the Ford workshop manual. That should get him the info he's looking for.
2000 F-Superduty Workshop Manual
It kind of reads like stereo instructions, but after playing around with it, you'll get the idea.
Old Oct 25, 2008 | 07:38 PM
Markadeck's Avatar
Markadeck
Gone, but not forgotten
Wow, I'm impressed. Please keep us informed and where are you located. I did not look at your profile so if it's there I apologize. You sure have come to the correct place for help. Welcome to FTE.
Old Oct 25, 2008 | 07:49 PM
iakobos's Avatar
iakobos
F350-6 that’s perfect. It’s exactly what I was looking for. I will advise him to join up. He’s been a little slow to take up computing and internet surfing but he’s coming around. This will be good for him.
Markadeck we live about 30 mi east of <?xml:namespace prefix = st1 ns = "urn:schemas-microsoft-com<st1:City>Crosby County</st1:City>, <st1:State>TX</st1:State>.
Old Oct 25, 2008 | 07:51 PM
Markadeck's Avatar
Markadeck
You know I'm such a dunce at these 7.3's that I do not even know if the cam is gear driven or chain. But the crank gear will most likely have a dot at 12 O'clock TDC. The cam gear should have one at 6 O'clock BDC of the gear. Now if there are advance or retard keyways I'm clueless and my advice comes from age old racing engine building days. The site is really dead today and there are plenty of members that know just what you want to know. But Chris's link should answer all of your questions for you and I am just wasting your time.
Old Oct 25, 2008 | 07:55 PM
iakobos's Avatar
iakobos
Chris that’s perfect. It’s exactly what I was looking for. I will advise him to join up. He’s been a little slow to take up computing and internet surfing but he’s coming around. This will be good for him.
Mark we live about 30 mi east of Lubbock in Crosby County, TX. Your input is also welcome.
James
Old Oct 25, 2008 | 08:08 PM
F350-6's Avatar
F350-6
Mark, there's a reason you've never read about a broken timing chain here.
Kris posted that pic a while back and I saved it. This motor is not at TDC, but if you really want to be confused about how engines work now a days, see the square indentions in the cam gear? Notice the larger square at the bottom, and the tiny square 180 deg opposite? That's what our lovely CPS reads to determine engine timing (no wonder we have issues). The larger square is under the CPS at TDC (or really close)
Old Oct 25, 2008 | 08:09 PM
4inchlovin's Avatar
4inchlovin
Wow what ever happened to manners?!?!?!
Welcome James! You have found THE BEST source for 7.3 info! Good luck and keep us posted please...
Old Oct 25, 2008 | 08:15 PM
Markadeck's Avatar
Markadeck
Yeah I kinda figured on the gear drive. But on a gasoline engine the gear whine is real noticeable, but the gear is much more efficient. I don't see a timing mark on the crank gear though, but if Pop has gotten as far as he has already without our help he is probably all set now. I just want to hear the results.
Old Oct 25, 2008 | 09:26 PM
iakobos's Avatar
iakobos
Thanks. I forwarded the link to my father. I'm sure he's been engaged in much reading since then. I'll keep every one up to speed on the rebuild.
And sorry about the double post. Something went haywire while I was working on the reply and now there are two.
Old Oct 26, 2008 | 04:10 PM
iakobos's Avatar
iakobos
Here's a few shots of the work in progress.
Old Oct 26, 2008 | 04:57 PM
F350-6's Avatar
F350-6
Thanks for the pics. We love pics. Tell your Dad to ignore the recall on the CPS. Unless there's a problem, he's better off keeping the one he's got.
Old Oct 26, 2008 | 05:18 PM
Markadeck's Avatar
Markadeck
Here's an example of how little I know about the 7.3
What's that item I have circled in red?
Old Oct 26, 2008 | 05:24 PM
iakobos's Avatar
iakobos
Thanks, I'll pass along the info.
I'll have to ask about the item you circled.
Old Oct 26, 2008 | 05:33 PM
F350-6's Avatar
F350-6
That's the oil cooler Mark. See the flat plate on the end toward the rear of the engine? The oil filter attaches there.
