driveshaft?
Old Aug 12, 2010 | 04:25 PM
baracade's Avatar
baracade
driveshaft?
Does my 03 7.3L 2wd have the slip joint that needs to be greased and what type of tool does it take to remove the bolts on the rear flange of the driveshaft?
Old Aug 12, 2010 | 06:25 PM
Snowseeker's Avatar
Snowseeker
No, the slip joint is in the transmission. The rear bolts are either 10mm 11mm or 12mm 12 point. I just did the U-joints on my 03 eddie 2wd and I forget what size the bolts were.
Old Aug 12, 2010 | 06:26 PM
Snowseeker's Avatar
Snowseeker
Sorry, the 12 point is just a normal 12 point socket or box end wrench. I used a socket, swivel, and an impact.
Old Aug 13, 2010 | 03:30 AM
brian Felts's Avatar
brian Felts
12 mm 12 point
Brian
Old Aug 13, 2010 | 06:56 AM
baracade's Avatar
baracade
Guess I misread other post, I thought the driveshaft had a slip joint in front of the rear u-joints. I looked at the rear flange bolts and they looked like the head of the bolts are similar to a torx socket?! How hard are they to remove, never been off and EX has 140k miles!
Old Aug 13, 2010 | 03:37 PM
brian Felts
I had to use a wrench on the front part and a socket or impact wrench on the rear.
Brian
Old Aug 13, 2010 | 05:21 PM
Monsta's Avatar
Monsta
Sit. Stay.
They look similar but they are just regular 12pt. A 12mm 12pt socket is all you need. It is found in most socket sets.
My 2wd had a slip joint. Never heard of one in a transmission.
You'll need to cut the straps off the boot. I didn't reuse mine. I just used zip ties.
Does your truck clunk upon take off?
Old Aug 13, 2010 | 05:29 PM
Mark Kovalsky's Avatar
Mark Kovalsky
Frmr Ford Trans Engr
I've never seen a slip joint inside a transmission. How would that work? Every slip joint I've looked at, and it is well into the thousands, has been in the driveshaft. They all need to be lubed at one time or another,
Old Aug 14, 2010 | 09:26 AM
baracade's Avatar
baracade
My driveshaft does not have this rubber boot, so I guess my problem will be in the u joints and drive shaft has a flange that mounts with 4 bolts to the differintial.
Old Aug 14, 2010 | 10:51 AM
brian Felts
My driveshaft had the boot but the problem was on the cv nuckle just before it bolted to the transfer case. I guess there was some kind of ball between them so I rebuilt the hole thing.
Brian
Old Aug 14, 2010 | 12:29 PM
baracade's Avatar
baracade
My EX is 2WD so I guess this is reason that I do not have the same setup, ie the rubber boot!
Old Aug 14, 2010 | 01:45 PM
EXv10's Avatar
EXv10
He is probably referring to a female splined yoke that slides into the tailhousing of a tranny which is very common.
Old Aug 17, 2010 | 07:27 PM
Snowseeker's Avatar
Snowseeker
Yes. I have found it normally easier to just say it is a slip in trans slip joint and the others a in drive shaft slip joint.
Old Aug 17, 2010 | 09:53 PM
EXv10's Avatar
EXv10
We just called it the yoke that goes in the tranny. They are all slip jonts any way you look at it.
Old Aug 18, 2010 | 06:28 AM
baracade's Avatar
baracade
So, what you are saying is that the splined shaft going into the trans tail housing has to be greased! It dosesn't get any lubrication from the trans, no rear seal in the trans!
