Sponsored by: Real Truck
diffrent drv shaft combos
Old Aug 12, 2010 | 12:40 PM
bohiaa's Avatar
bohiaa
hello gentelmen:
I have solved my issue with the shaking/bump, what ever ya wanna call it, at 32 mph through 34 mph, then again at 54mph.
I have a 2000 SD 4X4 v10. we removed the drive shaft, and drive the truck in 4 wheel drv and it was smooth as silk.
so it looks like at some point the ujoints were replaced. what were thinking is the drv shaft was NOT installed correctly,
with the carrier berring in the middle, how many diffrent combo's are there to switch the drv shaft around untill we find the correct position it should be in?
Thanks
Old Aug 12, 2010 | 12:56 PM
GUNNERDOG's Avatar
GUNNERDOG
It is held on at either end by 4 bolts i think... right? so there are:
4+3+2+1 = 10 permutations
Old Aug 12, 2010 | 03:02 PM
bohiaa's Avatar
bohiaa
with 2 shafts, shouldn't there only be 3 diffrent combos, that it could be ?
or am I wasiting my time ?
should I take it somewhere and have them balance it ?
Old Aug 13, 2010 | 11:00 AM
krewat's Avatar
krewat
FTE Leadership Emeritus
Did you check that carrier bearing?
Usually, the driveshaft is neutral balanced. So it really doesn't matter which way it is put back in. Service manuals usually say "mark it and put it back the way it was" just so that it's at least the same as before you took it apart. But I've found in reality that it just doesn't matter a whole bunch.
You MIGHT have a angle problem. Is the truck lifted at all? You might need to shim the carrier bearing either way.
Old Aug 16, 2010 | 08:39 AM
bohiaa's Avatar
bohiaa
it has NOt been lifted, and the carrier berring is in Great shape. it's NOT new but, it was checked several times. "firestone" goodyear, then the ford house.
the ujoints have greese fittings is why we think they have been replaced. and also I have herd of them not being in the correct postion. havent looked at that yet.
everything looks great under there, no clean marks where the drv shift may have been slipping or under any hard driving.
while at the shop we turned the front shaft 1/2 round. didn't work. I'm thinking that if I remove the front. turn it back where it was then turn the rear that's the only combos avaliable.....RIGHT ?
were in the country so taking it to have it balanced would cost me 2 days and a hotel.
any other ideals....
Old Aug 16, 2010 | 08:56 AM
redford's Avatar
redford
See if you can find a shop that does nothing but driveshafts in your area. Most metropolitan areas will have at least one.
bohiaa
Sep 6, 2010 11:06 PM
wdsmithjr
1997 - 2003 F150
Apr 23, 2007 05:09 PM
smashing4455
Feb 24, 2004 06:38 AM
screwdup2
Jun 4, 2000 05:28 AM
