Baffled???
Old Aug 12, 2010 | 02:15 AM
Helidriver's Avatar
Helidriver
Baffled???
Today I spent my afternoon working on the a/c for my 2000 X V10. Last week I had a seal blow on the compressor. While the situation sucked I knew I needed to work on the system anyway since the rear a/c didn't function.
I removed the rear interior so I could make sure the blend and directional doors were working and to get a better look at whats back there. It really seems like a simple set up. My suspicion has always been the expansion valve so I picked one up from the dealer and installed it. After the seal was replaced I threw in a new orifice valve, vacuumed the system and recharged.
When it came time to start the engine the front a/c went cold right away. Still needing to add more 134 I figured the rear would cool down soon enough. Once I finished the charge I had 37/204 (105 degrees) stabilized on the gages (my fancy new digital ones that make me look really cool to the neighbors). Still NO cold air in the back!!!! WTF???? The expansion valve and the evap discharge are not getting cold. It's like there's no flow. I traced the lines to make sure nothing was bent or crushed and everything appears ok.
I did take it for a short test drive and again nothing but warm air in back. The only thing I can think of is a blockage in one of the lines or in the rear evaporator. What else could it possibly be? Is there a screen or second orifice valve downstream that could be blocked?
Any ideas guys?
Old Aug 12, 2010 | 09:46 PM
ZBIGBIG19TH's Avatar
ZBIGBIG19TH
Just wandering, is there a blend door in the back for heat and A/C? Might be stuck.
Old Aug 12, 2010 | 11:22 PM
Helidriver's Avatar
Helidriver
Yep. That was my first guess too but it's working.
Old Aug 13, 2010 | 06:13 AM
ZBIGBIG19TH
You probably set them but ,all the controls front and rear are in correct positions?
Old Aug 13, 2010 | 08:57 AM
Helidriver's Avatar
Helidriver
Yep. Did that too. I tried turning on the heat and it works great. I think I've got a plugged line or evaporator.
tp79557
Aug 2, 2016 02:31 PM
sfxtech
Escape & Escape Hybrid
Aug 5, 2010 07:53 AM
wla6518
Aug 12, 2009 03:02 PM
pyrotech46
Oct 3, 2008 12:04 PM
Rock Hayag
Aug 9, 2004 04:10 PM
