LETS SEE YOUR MODS!
Old Aug 14, 2010 | 10:03 PM
  #31
Festus Hagen's Avatar
Festus Hagen
Methanoholic
Just be aware if you have plugs that are visible to the public some punks like to jack with them ... I had my service truck nearly burnt to the ground because some punk stuffed a pipe into the jumper plug!
I now mount them behind the grill, invisible unless specifically looked for.
-Enjoy
fh : )_~
Old Aug 14, 2010 | 10:11 PM
  #32
LCAM-01XA's Avatar
LCAM-01XA
Bud, all I gotta say is once you actually start wiring all this up you will be cursing the day you made that post I have several toggles on my dash and some are dual-throw, and that's more than enough sometimes, what you're planning on there is just a nightmare as far as the amount of work you'll be putting into it. But all the more power to ya man, I personally prefer making things automatic so I don't have to deal with them... Out of curiosity, why do you need line-locks for the front and rear brakes? Same with the hourmeters, what's the real usefulness of those?
Oh yah, where can one get such a bumper-though socket for the block heater?
Old Aug 14, 2010 | 10:44 PM
  #33
poocher pup's Avatar
poocher pup
lcam most rv store i've been in and some truck stops have that type of plug.
Old Aug 14, 2010 | 10:51 PM
  #34
WarOzz's Avatar
WarOzz
Sounds like blueovel is going for the top gun cockpit look. Tons of work in store for ya but it will look good.
Lcam I got mine at Cabelas in Reno for like $12 but you can find them online. Here is one site for same model I got, bit spendy though!
Marinco Connect-Charge Battery Charger Inlet
Old Aug 15, 2010 | 01:22 AM
  #35
LCAM-01XA's Avatar
LCAM-01XA
Ah, okay, I'll hit the RV dealer next time I'm in town, I need some other parts from them anyways, might as well add to the list...
Old Aug 15, 2010 | 03:45 PM
  #36
SnuffthePunkz's Avatar
SnuffthePunkz
Originally Posted by WarOzz
Cold air intake made from dryer vent parts.
When you installed this, did you have to re-enforce the radiator mounting? Or did it handle the hole being cut into it without a problem?
And did you add a piece of metal inside that looks like it's shaped like fan blades? for directing air flow in a certain pattern?
Old Aug 15, 2010 | 05:04 PM
  #37
poocher pup
also warozz did you cover it with any screen or leave it open. i ask because i've hit anything that walks, crawls, or flies across the road from the size of deer down and would be my luck i would suck a bird into it if left open.
Old Aug 15, 2010 | 06:27 PM
  #38
WarOzz's Avatar
WarOzz
I took the radiator bracket that was way overkill and just chopped it down into three pieces. Top with bolts left on, bottom with bolts left on, middle part in trash. So the radiator seems to have plenty of support, I can lay across it and it dont move... and I aint no small guy
I got some heavy duty screen with 3/8 squares that I have since mounted in front of the opening to keep big stuff out of the intake. I plan to wrap the outside of the pipe with exhaust wrap this weekend, that should stiffen it up a lot and keep engine heat from getting the tube hot and heating up the air. I will take some pics of it and the screen when done.
No on the fan blades... not really needed. I don't know if you can see in the pics but I did trim out a bunch of the plastic in the grill so that the intake get's direct flow.
The area in red is what I cut out, same on the two slots below it.
Old Aug 15, 2010 | 10:11 PM
  #39
Dave Sponaugle's Avatar
Dave Sponaugle
I only did one or two mods.
Old Aug 15, 2010 | 10:23 PM
  #40
WarOzz's Avatar
WarOzz
What everyone really wants to know Dave is what "one or two" mods you did to that engine that you have never told us about
Old Aug 15, 2010 | 10:48 PM
  #41
morimoto_87's Avatar
morimoto_87
WOW DAVE! Holy S@#T man, you really must love that good ol ford to make her that pretty, that motor is the cleanest looking 6.9 i've ever seen! So what have you done to that thing dave?
Old Aug 15, 2010 | 11:02 PM
  #42
Rick Wallace's Avatar
Rick Wallace
Did you think about wraping it with fiberglass cloth and resin? I thought about that when you first did yours.
Old Aug 15, 2010 | 11:10 PM
  #43
LCAM-01XA's Avatar
LCAM-01XA
Rick does your engine not move at all when you hit the throttle? If it does, and they all do to some extent (those with bad motor mounts more so than those with good motor mounts) and this can crack or even break your fiberglassed intake ducting
Old Aug 15, 2010 | 11:14 PM
  #44
Rick Wallace
Didnt think about that.......Ill figger out somthing when the time gets here to git it done..BTW, Right now my engine dont do anything!!!!!!
Old Aug 15, 2010 | 11:16 PM
  #45
LCAM-01XA's Avatar
LCAM-01XA
Not even just sit there and look kinda-sorta-maybe pretty? Cause that's all mine's been doing last week or so, lol
