Sponsored by: Auxito
Hmmm..
Old Aug 11, 2010 | 05:16 PM
C.Stranahan's Avatar
C.Stranahan
Hmmm..
Ok I have a 2000 ford f-150, my problem is that my engine is shaking and there is a knock. Usually when i'm decreasing in speed. I already changed the spark plugs and wires so i dont know. Can anyone help?
Old Aug 11, 2010 | 05:30 PM
n5926g's Avatar
n5926g
Welcome to the Forum....We are going to need more info to help diagnose the problem,CEL? Miles showing,V8/6,Automatic/Standard etc.If its the V-8 we,ll need to know the size,v-6 has always been (to my knowledge) a 4.2.
If you DO have a CEL(Check Engine Light) the code(s) would be helpful.
Im sure once the above info has been posted,someone will have some good pointers............
Old Aug 11, 2010 | 05:32 PM
93 mix 'n match's Avatar
93 mix 'n match
thrown rod? motor mount? the list goes on...
Old Aug 11, 2010 | 06:48 PM
C.Stranahan
It's a V6/ 4.2, Automatic. I tried a new coil pack too, but sadly still not the solution. It sounds like a diesel engine and it does shake when i give it throttle ( in gear). Some friends said it could be a fuel problem. I'm still unsure. However I'm taking it to get a compression test dont tomorrow.
Old Aug 11, 2010 | 06:50 PM
C.Stranahan
The CEL is on and it does two different codes i'm imagining. It will either stay lit or it will end up blinking alot. No, i haven't counted so I guess that is useless.
Old Aug 11, 2010 | 09:06 PM
steve(ill)'s Avatar
steve(ill)
i would be more interested in the codes than the compression readings.
Old Aug 11, 2010 | 10:49 PM
93 mix 'n match
well id imagine everyone can agree, its obviously a miss. a knocking sound, a shake, and a flashing CEL. time for new spark plug wires, spark plugs, and coil pack.
Old Aug 11, 2010 | 11:26 PM
Podaso's Avatar
Podaso
He said he already replaced that stuff. As mentioned before, CEL codes would be helpful.
Old Aug 12, 2010 | 09:52 AM
93 mix 'n match
he probably mixed up one of the wires. its either a problem with the ignition or with a fuel injector.
Old Aug 12, 2010 | 09:57 AM
C.Stranahan
No I did one at a time, just for that reason. So I know I didnt mix a wire up. I counted to 39 blinks before i quit counting.
Old Aug 12, 2010 | 10:00 AM
Recoil's Avatar
Recoil
Plugs and wires replaced already, I would replace coil pack.
When was the last time the fuel filter was replaced? If it is not a spark issue then it would be a fuel issue.
Old Aug 12, 2010 | 10:06 AM
93 mix 'n match
check for loose plug wires or loose injectors/wires. something like that.
a blinking CEL is a constant miss. enough of a miss to throw a code. so go to autozone and get your codes read.
Old Aug 12, 2010 | 01:18 PM
C.Stranahan
Well i tried some seafoam and still no luck. I had a master ford mechanic look at it too and he said that the compression is low.
Old Aug 12, 2010 | 01:33 PM
C.Stranahan
Now when I accelerate my battery light comes on.
Old Aug 12, 2010 | 01:53 PM
C.Stranahan
Well I guess it's time to tear apart the engine. Thanks for the help folks!
