Garage & Workshop Tips & Ideas for the garage or workshop. No Truck Tech Discussion
PVC is dangerous
Old May 20, 2003 | 03:38 PM
  #46
Torque1st's Avatar
Torque1st
Posting Legend
PVC is dangerous
The water pressure rating does not matter!!!
The problem with PVC is the material itself and it's failure mode!
PVC shatters like glass!!!!
PVC is NOT "rated to the air pressure involved", it is not rated for ANY air pressure!
ZIP ZERO NONE NADA!!!
The AIR pressure DOES cause the problem!!!
Pressurized gas will expand rapidly on release unlike liquids which don't (almost). The oil will attack the plastic but that is not what causes the failure.
For a remote air service, mount a small tank at the end of the line for an accumulator, and run 1/2" copper line underground. Slope the line so that it does not hold water anywhere along it's length. The tank should be at the lowest point. Put a good drain on the remote tank, it will collect a lot of water. If you are going up hill put a good drain where the line exits the structure.
Old May 20, 2003 | 06:26 PM
  #47
Freight Train's Avatar
Freight Train
PVC is dangerous
Hey, you can lead a horse to water, but......
You should make this thread a sticky, so it's always at the top.
I think what I need to do is blow up a piece of PVC, then we can post the mpeg, just for those who possibly need some material proof that playing with PVC for air service is like playing with fire.
I agree on the 1/2" copper for a remote to the house. But, it needs to be protected, or it will erode eventually. They make a product we use for gas called Enviro tubing. It comes with the jacket already on it, but it's not cheap. What I found to be cost effective, and it just works out better, is to take a roll of 1/2" k-tubing, (100 ft), roll it out, then snake it thru 1" well pipe, the same stuff used for your sprinklers. Just tape the end of the copper to keep out debris. (home depot well pipe, 25.00 for a roll) The copper goes thru fairly easy, and I think it's much better than the enviro tubing. For the connections, use a good silver solder, or braze them, or easier yet, flare them. Compression fittings aren't good on soft tubing, and thier illegal for gas or high pressure air in CT.
By the way, that's my all-time favorite smilie. I spend most of my days exactly like that.
Old May 21, 2003 | 12:13 AM
  #48
Torque1st's Avatar
Torque1st
Posting Legend
PVC is dangerous
Actually I have thought about a FAQ sticky that would contain tips and links to some of the more usefull threads.
Old May 21, 2003 | 10:53 PM
  #49
Faithful Old Road Dog's Avatar
PVC is dangerous
Great post! A friend of mine used PVC in his shop... until it burst. He said it was a big bang! Nobody was hurt. He replaced the PVC with type "L" copper pipe with soldered joints. Seems to work fine.
Old May 21, 2003 | 11:56 PM
  #50
Freight Train
PVC is dangerous
Eric, I think thats a great idea. I know that I could come up with all kinds of information to add in to a sticky all the time, safety, procedures, equipment FAQ's and recommendations. When I come across things that are relevant, I could send you a link, you look it over, if you like the way it looks, add it in. This could work, and it would be a good starting point for new readers.
Faithful, your friend should count his blessings. People are hurt every day due to unsafe practices. At least he replaced it with copper, too many would get another piece of PVC and put a dangerous system back into operation.
Jared
Old May 22, 2003 | 05:19 AM
  #51
Aten's Avatar
Aten
PVC is dangerous
Why would anybody bother using pvc when they can use iron pipe? Geez people, if you have to be cheap on something, do it on something that isnt exposed to 100 plus psi of air pressure. Common sense people, common sense.
Its like mechanical oil pressure gauges, there is a reason that you dont install them on a vehicle. The tubing can and will burst after so many miles, leading oil to fly out of the tube and blow up your engine, think about it. The same thing will happen when your pvc pipe blows up and your air compressor will stay on until it blows up.
Old May 22, 2003 | 12:47 PM
  #52
79Lariat's Avatar
79Lariat
PVC is dangerous
Steel pipe and fittings for air system---------$100
Six horse compressor with 60 gal. tank------$450
Me, standing in front of my piping system not worried about it blowing up-----------------------------------------PRICELESS
Old Jun 4, 2003 | 03:34 PM
  #53
casey1968's Avatar
casey1968
PVC is dangerous
We use PVC pipe dont get upset yet let me finish lol. At the compressor where it comes out we have a cut off valve when were done using everything we cut it off turn off the ocmpressor and flip a drainer open to release pressure. Just curouse what yall tinhk of this setup and yes if seen it blow up but not from pressure my ddad was cutting a hole for a out pipe on the wood stove and uhh he hit it lol freaked me out cause it let out a lot of pressure thats why6 we installed a few safegaurds
Old Jun 4, 2003 | 08:12 PM
  #54
79Lariat's Avatar
79Lariat
PVC is dangerous
casey1968,
First of all don't think that you are the only one I'm picking on, this is for everyone that keeps coming up with different situations, and asking will this be OK? Once and for all NO!!!
In some instances, not only is it ignorant, but it is illeagal to put any pressurized gas in PVC. PVC deteriates from so many factors that it doesn't require an impact to explode. Please people:
Don't install it
Don't use it if it's already installed
Don't ask "will it be OK if I", because it won't!
Old Jun 4, 2003 | 08:43 PM
  #55
casey1968's Avatar
casey1968
PVC is dangerous
lol ok i dont take it personally and it trly doesnt matter i have no control over this setup it is my dads shop after all hes run everything with PVC and has been doing so for years. Not my decision unluckily
Old Jun 4, 2003 | 08:52 PM
  #56
79Lariat's Avatar
79Lariat
PVC is dangerous
casey1968,
Then get him to read this ENTIRE thread. It's not worth going blind or dying to keep the PVC.
Old Jun 4, 2003 | 10:36 PM
  #57
casey1968's Avatar
casey1968
PVC is dangerous
I can try hes hard headed and against the net so itll be tough to ge thim to listen uhh what would be the best affordable replacement?
Old Jun 4, 2003 | 10:40 PM
  #58
79Lariat's Avatar
79Lariat
PVC is dangerous
3/4 galvanized pipe. Not really that pricey, just a little work cutting and threading. Good luck.
Old Jun 4, 2003 | 10:43 PM
  #59
casey1968's Avatar
casey1968
PVC is dangerous
Thanks for the idea now if i can jsut get my parts washer built lol
Old Jun 4, 2003 | 11:05 PM
  #60
Freight Train
PVC is dangerous
People can also use black steel pipe for air service 79Lar, (otherwise known as black iron)
Gal pipe would be the best choice, but regular black steel will work fine. A threader will rent out for probably 25 dollars for the weekend. A very worthwhile upgrade from PVC.
Anyone not familiar with plumbing should be aware that installing steel pipe, or even copper pipe requires a 1/4" per foot for drainback on the horizontal runs, and the downlegs should have a drip leg on each one. (min. 3" nipple with a cap) Instead of using a cap on my driplegs, I like to put a ball valve there, this makes it easy to drain the traps every week. Only exception to this rule is a downleg that goes outside, a drip leg will freeze and break in the winter. Instead, come down an inside wall, into a Tee, then install the drip leg, then off the branch of the tee, a short nipple out side, and the fitting.
NEVER connect rigid pipe directly to the compressor, a three foot snubber is required to dampen the vibes.
One other thing, it's illegal everywhere. OSHA banned the use of pvc pipe for pressurized air and gases some time back.
educate yourselves
