Power Problems
Old Aug 10, 2010 | 10:48 PM
rtorres's Avatar
rtorres
Power Problems
2004 f350 PSD 6.0 125000 happy miles. My emmision light came on and my truck lacks power. On start up I dont hear the turbo. What should i be aware of and costs? PLEASE HELP
Old Aug 10, 2010 | 11:01 PM
bradyracing's Avatar
bradyracing
I have an 04, what does the emmisions light look like?
Old Aug 10, 2010 | 11:14 PM
rtorres's Avatar
rtorres
its on the left bottom corner and it looks like an engine
Old Aug 10, 2010 | 11:25 PM
bradyracing
That is the check engine light, need more info, codes would help a ton.
Old Aug 10, 2010 | 11:43 PM
rtorres's Avatar
rtorres
acorrding to the owners manuel its a emmision lighght and a check engine light
Old Aug 11, 2010 | 06:55 AM
bismic's Avatar
bismic
There is a troubleshhoting thread on "low power" in the Tech Folder, You might want to read through it.
Reading the codes would help a great deal.
Any smoke when starting up or running?
Old Aug 11, 2010 | 09:03 AM
rtorres's Avatar
rtorres
bismic thank you there is no smoke. My gut feeling is expecting a turbo problem. If that is the case is there a recommended upgrade that is cost effective
Old Aug 11, 2010 | 10:12 AM
bismic's Avatar
bismic
Don't jump to a solution too quickly. These engines are complicated. Can you get the codes read somewhere?
Old Aug 11, 2010 | 10:19 AM
rtorres's Avatar
rtorres
Bismic, again thank you I tried calling a trustworthy diesel mechanic he might be on vacation. So right now im searching.
Old Aug 11, 2010 | 10:24 AM
bismic's Avatar
bismic
See if autozone or somewhere like that can help you. Sometimes their code readers will not pick up all the codes, but it is a start.
Old Aug 11, 2010 | 04:22 PM
rtorres's Avatar
rtorres
First code is P2290 icp to low. The voltage is set for 18-24 my read 12. Did get the truck to run and code P2291 came up
Old Aug 11, 2010 | 08:09 PM
bismic's Avatar
bismic
Are you having trouble starting or just low power?
It could be an issue with the IPR or high pressure oil system.
Old Aug 16, 2010 | 05:53 PM
rtorres's Avatar
rtorres
It does'nt start. Replaced ICP because low voltage. Still did'nt start. IPR showed low pressure at around 490 psi replaced IPR and still no luck.
Old Aug 16, 2010 | 06:25 PM
bismic's Avatar
bismic
You may want to do an air pressure test to see if you can identify a leak in the HPO system.
To do that you need to connect an air line to where the ICP sensor is, command the IPR closed by applying 12 V (but for only 30 seconds), and then listen for leaks.
Is your ICP sensor on the passenger valve cover or behind the turbo?
Old Aug 17, 2010 | 10:02 AM
rtorres's Avatar
rtorres
Did the pressure test and did'nt hear any leaks. I believe my icp is located behind the turbo on the drivers side valve cover
