Power Problems
Aug 10, 2010 | 10:48 PM
Power Problems
2004 f350 PSD 6.0 125000 happy miles. My emmision light came on and my truck lacks power. On start up I dont hear the turbo. What should i be aware of and costs? PLEASE HELP
Aug 10, 2010 | 11:01 PM
I have an 04, what does the emmisions light look like?
Aug 10, 2010 | 11:14 PM
its on the left bottom corner and it looks like an engine
Aug 10, 2010 | 11:25 PM
That is the check engine light, need more info, codes would help a ton.
Aug 10, 2010 | 11:43 PM
acorrding to the owners manuel its a emmision lighght and a check engine light
Aug 11, 2010 | 06:55 AM
There is a troubleshhoting thread on "low power" in the Tech Folder, You might want to read through it.
Reading the codes would help a great deal.
Any smoke when starting up or running?
Aug 11, 2010 | 09:03 AM
bismic thank you there is no smoke. My gut feeling is expecting a turbo problem. If that is the case is there a recommended upgrade that is cost effective
Aug 11, 2010 | 10:12 AM
Don't jump to a solution too quickly. These engines are complicated. Can you get the codes read somewhere?
Aug 11, 2010 | 10:19 AM
Bismic, again thank you I tried calling a trustworthy diesel mechanic he might be on vacation. So right now im searching.
Aug 11, 2010 | 10:24 AM
See if autozone or somewhere like that can help you. Sometimes their code readers will not pick up all the codes, but it is a start.
Aug 11, 2010 | 04:22 PM
First code is P2290 icp to low. The voltage is set for 18-24 my read 12. Did get the truck to run and code P2291 came up
Aug 11, 2010 | 08:09 PM
Are you having trouble starting or just low power?
It could be an issue with the IPR or high pressure oil system.
Aug 16, 2010 | 05:53 PM
It does'nt start. Replaced ICP because low voltage. Still did'nt start. IPR showed low pressure at around 490 psi replaced IPR and still no luck.
Aug 16, 2010 | 06:25 PM
You may want to do an air pressure test to see if you can identify a leak in the HPO system.
To do that you need to connect an air line to where the ICP sensor is, command the IPR closed by applying 12 V (but for only 30 seconds), and then listen for leaks.
Is your ICP sensor on the passenger valve cover or behind the turbo?
Aug 17, 2010 | 10:02 AM
Did the pressure test and did'nt hear any leaks. I believe my icp is located behind the turbo on the drivers side valve cover
