Kiggy has it about right! The DPF will trap the soot to be burned and out the pipe it goes as harmless ash.
Tips are to avoid extended idling. short frquent stops and not getting the truck up to normal operating temps.
Cold motor produces more soot.
So how can you help?
Try lower gears and tow/haul mode if regening in the city. This will produce higher rpms and higher EGT's so you can ensure that the injected fuel on the exhaust stroke goes to the DPF.
Also learn your trucks average regen cycle. May or may not be helpful in knowing when it may occur. Not an exact sience.
Let me add this as well. On occasion I true think it is better to stop a regen if it has just started and you are at your destination. This to me is much better than wandering around trying to get it done. Just know that as soon as you are up to operating temps it will start again.
This is somewhat helpful for me as I know to plan it.
Having said all this, I really have no issues with the regen process. I generally just ignore and drive the truck. maybe It is all habit by now I do not know.
What I do know is I dont make oil.
Reason: more info
Looks like I am going to have to read more about this regan cycle. and be sure to check oil with fill ups. I guess if level increases before 5000 miles you still need to change it.
I've read on this forum that its actually recommended when doing oil changes to leave the oil level at the low end of the stick just in case you start making oil. Either way, always best to check frequently.
In one of the posts above, the coolant level was mentioned. It was also stated not to use tap water but deionized water. What is the difference and will it harm the engine in a small amount? This is my first diesel and the learning curve has been steep. Regarding the regen, a regen occurs about every 300 miles and only lasts about 5-7 miles. I do not mind the message but will a computer update increase the time between regens? My mileage is between 11.5 and 12 and that is highway driving. I expected worse mileage compared to my 5.4L but this seems a little extreme. It is a 2008 f-250 job 1 (6/07).
I am an easy driver - rarely do I push it over 2000 rpm's. I was really expecting better MPG - gonna try diesel kleene in my next tank. I would like to learn more about the coolant and how the motor is affected. Any suggestions? If the nitrate level is not good is the only fix a flush and refill?
you can try some test strips to check the strength, Rotunda #328-00001 is the kit. If the nitrates are low 300-800 ppm then you can add 32 oz of VC-8 to bring it up.
If lower then a flush is required. Check every 20K.
Not maintaining the right strength could cause cavitation in the cooling system.
Tap water isn't recommended for any radiator, this isn't a diesel specific thing. There are too many minerals in tap water that will eventually started to precipitate out and build up in your motor's coolant passages. If it's just a cup or two I probably wouldn't worry about it, but if you filled your cooling system with 50% af and 50% tap water you would def need to flush and start over, using distilled water instead.
I bought my first diesel, 2008 F350. I am wondering what exactly you have to do for maintenance. I was told 7,000 miles for oil change/filter. I have read about a water filter? drainage, fuel filter? What other things do you have to do/check/replace and when. I know on a gas burner 3 months/3000 miles oil change with filter and lube and check air cleaner. But diesels are a different animal. Really dont need one( dont haul anything) just have always wanted one. Do you guys use ford parts from stealership or is there a better place?
