6.4L Power Stroke Diesel Engine fitted to 2008 - 2010 F250, F350 and F450 pickup trucks and F350 + Cab Chassis
Service engine light came on
Old Jul 20, 2010 | 08:32 AM
grizzlander's Avatar
grizzlander
I have a 2008 F350 diesel dually with 6500 miles on it (I know, I know I need to drive it more) I just started it after setting idle for 3 weeks while I went on vacation, well after about 1 mile the engine light came on. Any ideas what could cause this and will it be safe to drive to my closest dealer (85 miles away). It was completly serviced at 5000 miles. Thanks in advance.
Old Jul 20, 2010 | 09:05 AM
senix's Avatar
senix
Check all fluids and drive it in. Hard to say, but maybe batteries since it had been sitting.
Old Jul 20, 2010 | 02:46 PM
grizzlander
Thanks for the reply! So if it is the batteries can I just hook it to a charger and charge the batteries to get the engine light to go off?
Old Jul 20, 2010 | 02:53 PM
ChargersFanInCO's Avatar
ChargersFanInCO
It could be a hundred things, but drive it first to see if the batteries charge back up. Do you use a fuel stabilizer in it?
Old Jul 20, 2010 | 04:27 PM
Rudiak's Avatar
Rudiak
Am I missing something here? You need to scan for codes.
Old Jul 20, 2010 | 07:05 PM
Larry NCKS's Avatar
Larry NCKS
Ditto on scanning for codes. Conventional wisdom is if the light is solid it's OK to drive for a short distance, but if it's flashing shut it down.
Old Jul 20, 2010 | 07:12 PM
Larry NCKS's Avatar
Larry NCKS
oops! intended this to be new thread. can't figure how to entirely delete it.
Old Jul 21, 2010 | 06:36 AM
grizzlander
How do you do this?
Old Jul 21, 2010 | 07:02 AM
Larry NCKS's Avatar
Larry NCKS
Originally Posted by grizzlander
How do you do this?
get an OBDII code reader and plug it in to the datalink below the dash and to the left of the steering column.
Otherwise, some autoparts stores like O'Reilly's and others will read codes for you for free.
Old Aug 13, 2010 | 09:48 PM
AlbyVA's Avatar
AlbyVA
My check engine light came on back in Jan/Feb. Guess what I got as a
post Christmas present?
Fuel Filters -- The $3200 Story - Ford Powerstroke Diesel Forum
$8,292.64 Repair - Failed Fuel Filter - Ford Powerstroke Diesel Forum
Old Aug 14, 2010 | 12:27 AM
Ray Freeman's Avatar
Ray Freeman
My 08 build truck used to have the check engine light come on reguarly. When I had the codes checked it was a exhaust filter hiccup everytime. The light would go out after a few days. A Spartan program with the DPF delete has fixed all that.
