Transmission electrical problem?
Old Aug 10, 2010 | 08:06 PM
77-250's Avatar
77-250
1995 F150 2wd 300 six 3 speed auto with OD
Dad told me he was driving down the road, all of a sudden the speedo stops working, odometer stops working, abs light comes on and the transmission is shifting very firmly and seems to free wheel when coasting. My first thought was to replace the speed sensor in the rear end, no sensor in the transmission. Didn't fix the problem, thought I may have looked over something easy, checked fuses, ok. Where to next?
Thanks
Old Aug 12, 2010 | 05:50 PM
77-250's Avatar
77-250
input ? bump
Old Aug 12, 2010 | 06:00 PM
dustybumpers's Avatar
dustybumpers
if it has a fr70w trans, it has a speed sensor on the left side. nthis trans has 20 bolts, and says metric on the pan
Old Aug 12, 2010 | 06:10 PM
subford's Avatar
subford
That is a output shaft sensor, not the speed sensor for the speedometer on the 4R70W transmission.
Old Aug 12, 2010 | 06:21 PM
subford's Avatar
subford
You can start by unplugging the RABS module and see if the speedometer starts working again.
Check all the wiring down the drivers side frame rail to the rear end.
Recheck the fuses for the speedometer, namely #8 and #18 in the dash fuse panel.
Old Aug 12, 2010 | 08:31 PM
77-250's Avatar
77-250
I can do that, can you point me toward the RABS module? Does this truck have the E4OD?
Thank you!
Old Aug 12, 2010 | 09:07 PM
subford's Avatar
subford
My guess is that you would have the E4OD.
The RABS Module is C-1 in the diagram below:
Old Aug 12, 2010 | 09:16 PM
77-250's Avatar
77-250
Thank you, will report back!
Old Aug 14, 2010 | 11:01 AM
77-250's Avatar
77-250
UPDATE
Unplugged RABS module, speedo is working, along with odometer, transmission is shifting normal. The ABS light also went out. I'm assuming I need a new RABS module if I want the ABS to work.
Thanks!
Old Aug 14, 2010 | 11:10 AM
subford's Avatar
subford
That would be my guess.
Bucky623
1997 - 2003 F150
Sep 13, 2016 02:56 PM
KC Excursion
Jul 6, 2016 03:22 PM
Bonanza35
13
Dec 29, 2015 02:52 PM
deemac
Aug 3, 2010 12:37 AM
austin richard
Aug 2, 2002 11:03 PM
