Sponsored by: Real Truck
siphoning easy
Old Aug 11, 2010 | 03:36 PM
bpounds's Avatar
bpounds
Originally Posted by sdetweil
based on this chart, 1/4in tubing, (1/2 the smallest here) would be around 3 gallons per minute and 180-200 gallons per hour..
GPM/GPH Flow based on PVC Pipe Size, ie, How much water can flow through Sch 40 Pvc Pipe Size 1/2" 3/4" 1" 1.5" 2" 2.5" 3" 4" 6"
easy to empty a 35 gal tank.. 10 mins..
sam
Point of fact, .25"dia. is not half of .5"dia. It is much less than half.
.25"dia. = .02"^2
.50"dia. = .79"^2
So approximately 1/4 the flow. But your point is a good one anyway.
Even less through a Schraeder valve. But I guess it has been done and works okay. Good info to squirrel away.
Old Aug 11, 2010 | 03:48 PM
sdetweil's Avatar
sdetweil
.25"dia. = .02"^2
.50"dia. = .79"^2
yes, right, exactly 1/4 the area size. (3.14159*(.125**2))/(3.14159*(.25**2))
| it is 1/2 the diameter of the smallest one in the table I referenced.
Sam
Old Aug 11, 2010 | 04:37 PM
GUNNERDOG's Avatar
GUNNERDOG
It may be 1/4 the cross sectional area, which means the average fluid velocity will be 4x higher in a 1/4" line vs a 1/2" line, however the important factor in flow rate is pressure drop.
At 1gpm a 1/4" line will produce a pressure drop of about 40 psi/100ft
At 1gpm a 1/2" line will produce a pressure drop of only 1.5 psi/100ft
that is almost 30x higher pressure drop which indicates that siphoning with a 1/2" line will produce approximately 30x higher flow rate than the 1/4" line.
That PVC flow rate chart is decieving. It says "gravity flow" but you have no idea how long the pipe is or how many feet of head are pushing down on it. I am guessing you will get much lower flow rates. Get the biggest piece of tubing you can jam in there.
Old Aug 11, 2010 | 04:49 PM
sdetweil's Avatar
sdetweil
Originally Posted by GUNNERDOG
...Get the biggest piece of tubing you can jam in there.
yeh, I can't imagine using 1/4 in hose for anything anymore..
sam
Old Aug 12, 2010 | 09:58 AM
Fishin76's Avatar
Fishin76
If you use the in-tank fuel pump to empty the tank at a fuel line in the engine compartment, don't forget to change the fuel filter before running the engine. if varnish has started to form, the particles may clog the filter. That varnish is some sticky stuff.
Old Aug 12, 2010 | 10:21 AM
GUNNERDOG's Avatar
GUNNERDOG
Or better yet, pull the filter out and put a hose over the filter inlet and pump it out from there. Careful though, that pump uses the gas in the tank for cooling.
Old Aug 12, 2010 | 12:10 PM
Wagion's Avatar
Wagion
How old is old? I've stored vehicles for over a year with the gas tank full to prevent condensation and then driven them till old gas is gone then dump in a can of engine conditioner / injector cleaner fill up with fresh gas an good to go.
Someone ask what to do with it if you did drain it put it in 5 gallon cans and put one can in each time you fill up so you dilute it with fresh gas.
Bohemian
Modular V10 (6.8l)
15
Oct 20, 2020 07:26 PM
lameousername
Sep 6, 2015 04:17 PM
Knothole
Jul 7, 2012 11:58 AM
michael cook
2009 - 2014 F150
16
Dec 1, 2011 03:13 AM
79F-350
Jan 12, 2011 01:00 AM
