4.5 years later.....yes....same answer. The problem is going to be the computer in the truck now is expecting to be connected to an electronic controlled E4OD. With that missing the Check Engine Light is going to glowing all the time the truck is running.
If you do not want to see that you will need to source a computer (PCM) from a manual or AOD equipped truck.
From what I've read, this isn't true. It will store some codes because of the missing transmission, but it's not going to trip the light. If you have an E4OD computer, which is unusual but not unheard of, it will work fine with a non-computer controlled transmission like an AOD, C6 or a manual.
My turn, so I just popped the 300 in my 1980 f150 4x4 with a granny low 4 speed. I have an extra 351w and a 460. The Windsor has a C6 bolted up and the 460 has a 2x4 4 speed. What would you guys do?
No, my motor let go not the tranny. I'm just trying to decide if I should swap to a 351w that will need a flywheel and clutch and motor mounts or swap the bellhousing in the truck and drop in my 460 that is already set up for a manual.
Ok I have my grandpas ole 85 f150 with a straight 6 and manual 3 speed on the column, just purchased a 95 f150 with a 302 with auto trans I'm looking to swap my manual transmission with the auto will it work ? And what do I need to make this work ???
