2005 Expedition transmission = dead?
Old Apr 30, 2018 | 04:06 PM
  #61
ayden2004's Avatar
ayden2004
Originally Posted by jk080
It should have a 4R75W transmission.
As far as the problem goes, the overdrive servo pistons has a small e clip the holds the servo together, this clip is known to break and fall down into the valvebody and jam the valve for 4th gear. If you can find a shop that is willing to remove the valvebody and check this out you might be able to fix it without rebuilding it.
Just so you know sometimes when the clip brakes it can cause the overdrive band to burn, once the pan is off you should be able to tell by the smell of the fluid and of any black debris in the bottom of the pan. You may end up having to rebuild it anyways, I would say that you have a 50-50 chance.
So I found this thread through another on f150s. you note in here that this was an issue with the 4r75w am i safe in assuming it would be a good possibility this is my issue with the 4R75E In my 05 f-150? does exactly what the ops post states drives fine as long as over drive is off. with o/d on it essentially goes into neutral
Any help would be great cause its my work truck and i don't want to damage it farther but can't afford to leave it home.
thanks
Old Apr 30, 2018 | 10:30 PM
  #62
jk080's Avatar
jk080
Transmission Rebuilder
The overdrive band has to apply during the 3-4 shift, if it doesn't apply it will feel like a neutral because the forward drum is released during that shift, so yes your description of your problem could be the stuck valve but you will need to remove the valve body to find out.
It is common to have the e clip and or the snap ring to break and pieces can get caught in the valve body and prevent the valve from moving, but I also see the band broken and or burnt as well.
Banks_93_IDI
15
Feb 27, 2018 03:23 PM
Martok
Jan 3, 2018 01:24 PM
Krameraxe
Aug 19, 2016 08:02 PM
mytrustyford
20
Aug 15, 2016 03:30 PM
deputydog03
Mar 16, 2016 09:42 AM
