Starting problem getting old.
Old Aug 20, 2010 | 07:40 PM
  #31
phurst's Avatar
phurst
I'll let it sit over the weekend and check the bowl Monday evening. Thanks for the reminder.
Old Aug 20, 2010 | 08:49 PM
  #32
bashby's Avatar
bashby
You might just need to pump the gas more before you start it.
Old Aug 20, 2010 | 09:13 PM
  #33
Plums72's Avatar
Plums72
repped bashby for you Jim.
Old Aug 21, 2010 | 03:15 PM
  #34
Wicked Endings's Avatar
Wicked Endings
I gave you some rep!
I thought you deserve it!
Old Aug 24, 2010 | 12:01 PM
  #35
phurst's Avatar
phurst
I used the truck last night. Pumped the gas 4 or 5 times and it fired right up. Now I don't know what to think. i didn't ave time or light to check the level in the bowl. Guess I should let it sit for a week+ and see how it is.
Old Aug 24, 2010 | 12:31 PM
  #36
LARIAT 85's Avatar
LARIAT 85
If you let a carbureted vehicle sit for a couple of days, normal starting procedure should be as follows:
1. - Turn key to "start."
2. - Press accelerator pedal all the way to the floor (to set the choke).
3. - Pump accelerator pedal once or twice and release.
3. - Crank engine.
If you let it sit for a week or more, what happens is the fuel has started to evaporate out of the carburetor's fuel bowl(s). When this happens, your starting procedure is going to be a little bit different:
2. - DO NOT PUMP THE GAS YET. Crank engine for about 10 seconds. This will energize the fuel pump and get gas back to the fuel bowl.
3. - Press accelerator pedal all the way to the floor (to set the choke).
4. - Pump accelerator pedal three or four times and release.
4. - Crank engine.
If your engine still fails to start, you have another problem somewhere. If the accelerator pump diaphragm checks out ok, check your fuel pump for leaks.
Old Aug 30, 2010 | 09:19 AM
  #37
phurst's Avatar
phurst
Ok, I used the truck this weekend, and followed procedure #2 above. Cranked for about 10 seconds, set choke, pumped gas 3-4 times, and it fired immediately and died. Pumped 2-3 more times and it started up fine. This is acceptable to me, but is it normal?
Old Aug 30, 2010 | 11:18 AM
  #38
LARIAT 85's Avatar
LARIAT 85
Yes, that sounds normal.
The next time you have to use procedure #2, after you crank the engine over for 10 seconds, try pumping the pedal 5 - 7 times and then see if it starts up. Any more than that and you will probably flood the engine, so don't!
Old Aug 30, 2010 | 11:25 AM
  #39
phurst's Avatar
phurst
Cool, thanks. I can't rep you again though
Eighty_Six
Jul 6, 2014 06:32 AM
moonshine34
Jun 9, 2013 09:23 AM
Kurt G.
Jun 3, 2013 10:03 AM
swampthang
19
Mar 30, 2013 08:24 AM
BossFan
19
Aug 20, 2011 06:59 PM
