Where to source these items?
Old Aug 9, 2010 | 05:31 PM
mdacton's Avatar
mdacton
LMC has a few of these thing but only a few.....
shortbed pass side front lower half
cab corners
cab mounts front
center cab supports
both sides floor pans
the rubber mounts and hardware for front of cab and radiator support.
thats enought to get me started for right now with this project
Also does 70s model rad support fit these also?
Old Aug 9, 2010 | 07:17 PM
Broomfieldbum's Avatar
Broomfieldbum
What year is your truck??
Old Aug 9, 2010 | 07:54 PM
mdacton's Avatar
mdacton
1966 f100 2wd shortbed
Old Aug 9, 2010 | 09:25 PM
Broomfieldbum
shortbed pass side front lower half- I don't know anyone who is selling this part. Your best source is to find a donor. I found a complete bed to get the parts I needed cheap in my area.
Dennis Carpenter or Blue Oval Ford Parts should have everything else you need.
A couple of other notes, The floor boards out of 65-73 are all the same. I have heard they are the same all the way up to 79, but all the catalogs show 65-73.
Unfortunately the radiator supports for 66 are not available. I haven't gotten to that point yet, but I plant to modify a 64 support for my 66 short bed.
Good luck. Keep up with the forums, you can always get a few different perspectives on any issue and mostly good advice on any issue you come across.
Old Aug 9, 2010 | 10:45 PM
Bill W's Avatar
Bill W
Old Aug 10, 2010 | 06:16 AM
ddavidv's Avatar
ddavidv
Absolutely Carolina Classics over LMC. Or Flashback F100s. Either way you are talking to people who actually know our trucks, not just some guy sitting behind a phone who drives a Subaru to work.
The 70s rad supports WILL NOT WORK. You need to either find the rare as hen's teeth '66 or simply modify one of the 61-64 repro ones to work (it ain't that hard).
No one makes bed side patch panels, or bed floor patches, at present.
Old Aug 10, 2010 | 08:50 AM
garbz2's Avatar
garbz2
Well having actualy been to LMC in Kansas i can say the counter persons there did not drive subarus to work. In fact there were a few had old Fords or Chevies, Imagine that.......
Garbz
Old Aug 10, 2010 | 11:20 AM
bagpype's Avatar
bagpype
I use melvins classic ford parts here in ga.
Old Aug 10, 2010 | 03:40 PM
NumberDummy's Avatar
NumberDummy
Ford Parts Specialist
(There are two different types of '66 supports, only one is correct for the OP's truck.).
Or simply modify one of the 61-64 repro ones to work (it ain't that hard).
C2TZ16138G .. Radiator Support / Obsolete/Reproduced
Fits: 1961/64 F100/250 2WD/4WD / 1961/66 F350/600 / 1965 F100/250 4WD / 1966 F250 4WD.
The following is the original and correct 1966 support for the OP's truck:
C6TZ16138B .. Radiator Support / Obsolete / Fits: 1966 F100/250 2WD only.
The other 1966 radiator support is: C6TZ16138C which fits 1966 F100 4WD & 1965 F100/250 2WD.
