Question about carb and efi intake manifolds
Completely. There's very little differences between the EFI and carbureted blocks.
The issue you may run in to is some binding with the EFI exhaust manifolds. There are a few places where they try to occupy the same space (since they were never designed to go together.) On mine, when I put EFI exhaust manifolds with my carb intake, it was one of the eyelets on the exhaust manifold, and a nub that stuck out on one of the runners. A little grinding is all that's needed to remove both.
EFI head has (3?) more bolt holes than a carbed head, but they are otherwise the same on the outside. I believe the extra bolt holes were simply used to allow easier mounting of the manifolds since the 2 exhaust and 1 intake were not joined on the EFI like they were on the carbed setup. On the EFI, you have to hang 3 seperate pieces that still use the shared bolts to hold them on.
Quantrex
12-07-2002 09:25 PM
karlsd
11-08-2001 07:56 AM
