Jag Front IFS alternative.
Old Aug 8, 2010 | 11:00 PM
Aussie 53's Avatar
Aussie 53
Here's a post for all people who are comtemplating installing a Jag IFS in there trucks. This alternative way of installing the IFS was in stalled in a 53 to 56 frame. If you have some welding skills this alternative is quite simple but it has some draw backs in it. The first draw back is that the Jag cross member has an 75mm insert welded into it to make the cross member longer which will enable it to sit under the chassis rail nicely, then you have to source a doner rack and pinion to suit the existing jag one. The the shock towers will pretrude into the inner guards which will have to be modified. Here are some ruff pictures of how it was done.
