1978 - 1996 Big Bronco
Bronco Differental Questions
Old Aug 8, 2010 | 06:46 PM
Mavericks9's Avatar
Mavericks9
Big Question.
I just ordered 4.11 gears for the ford 8.8 rear differential from Randys.
DO I HAVE TO REPLACE THE FRONT GEARS TO.
ALSO WHAT TYPE OF FRONT IS IT? (93 bronco)
I'm guessing its a dana 44, but thats a huge guess, please help.
Old Aug 8, 2010 | 07:27 PM
Encho's Avatar
Encho
The Southernmost Mod
Yes, all diffs. should have similar gears, you could have maybe 4.10 front and 4.11 rear, but that should be the biggest difference you should have in your truck. The front diff. should be a Dana TTB (Twin Traction Beam) 44, the internals should be the same as in a Dana 44.
Do some research on the TTB so you familiarize yourself with it, and do check that your Bronco's TTB hasn't been swapped (swapping for a Solid Axle is a mod some Bronco owners do).
Old Aug 8, 2010 | 07:38 PM
Mavericks9's Avatar
Mavericks9
Ive got a 300hp engine, with 3.55 gears.
will the 4.11 gears give me more performance.
Also will i effect mpg?
Old Aug 8, 2010 | 07:57 PM
Mavericks9's Avatar
Mavericks9
Is the 8.8" rear gears in the bronco reverse or standard?
same question with the front gears.
trying to go ahead and order the gears,
Old Aug 8, 2010 | 09:40 PM
Encho's Avatar
Encho
4.11 will give you more pulling capability, and a better acceleration, it will barely affect MPG, if you have OD you'll be even better. About the reverse or standard... i actually don't know, that will probably be stated somewhere in the Owner's Manual, get the PDF for a 96 Bronco here, they will be almost the same: https://www.fleet.ford.com/maintenan...ls/default.asp
Old Aug 8, 2010 | 09:49 PM
DLP Performance's Avatar
DLP Performance
The rear 8.8 is standard rotation. The front D44 TTB is reverse rotation. Your RPMs will increase by about 700 or so from where they are now while driving. So, if you're running 60mph now at 2,000rpm, you'll be turning around 2,700 after the swap.
Old Aug 8, 2010 | 11:03 PM
Mavericks9's Avatar
Mavericks9
Talking
I guess its a good thing i have overdrive then. Currently im getting 12mpg average with the crate motor, and 31in tires (305/65/18).
On a 3.55 gears. I dont pull a lot of weight. Have a 14ft fiberglass fishing boat but that aint nothing.
Want the 4.11's cuz it sounded like like the 2in body lift and 33in tires i plan to install, i would get optimal performance of of it. Especially while off road.
The 12mpg i get know would probably be around 11mpg with the 4.11 rear end.
Which ill deal with.
at 60mph i'm pushing 2100/2200 RPM. IN OVERDRIVE.
Really interested to see how the smoothly the lift goes. and how the tires an all look.
Old Aug 8, 2010 | 11:55 PM
DLP Performance
4.11s & 33s should work well together. Get a Superlift speedo calibrator & set your speedo to the gear ratio & tire diameter for best results. My '93 got 13 in town & 16 interstate, stock. 3.55s & 31s. You can put 33s on it w/o any lift. You'll just need to put spacers on the front bumper brackets to bring it out an inch or so. You can also put spacers under the coil springs & get up to 2". You'll just need to get the Camber reset at the alignment shop afterwards.
Old Aug 9, 2010 | 12:05 AM
Mavericks9's Avatar
Mavericks9
Thumbs up
Thanks for the Tips, and the various info.
Ive decided to order the following Tomorrow morning
From [www.broncograveyard.com]
1) Yukon 8.8" Ford Ring and Pinion, 3.73 ratio
$122.99
2) USA Standard Gear D44 Reverse Rotation 3.73 ratio
$139.99
3) Body Lift, 3" 1992-96 Bronco
$119.99
*** expect to purchase some 33x12.5x18 mud terrain tire. Getting the best priced i can FIND
AND recommendations are appreciated.***
Gonna try the body lift, may be purchaseing the:
4 inch Deluxe Lift Kit 1990-96 Bronco/F150 and adding the Shocks plus drive shaft extension. Hopefully body lift will due tho.
Old Aug 9, 2010 | 12:15 AM
Mavericks9's Avatar
Mavericks9
I forgot to explain y i decided on 3.73 and not 4.11's.
The simply reason is im afraid 700RPM increase is alil to much for gas,etc.
I think 300-350RPM will be perfect.
Add some performance for off road, with the body lift an 33/12.50/18
super swamper's. But not sacrifice MPG on the 30mile commute to and from work.
When i get my gears/pinions/and lift just gonna take it to the mechanic and let him do it to it. Expect a $$250-300$$Bill for the install.
Then gna focus on the rear window and the 4x4 Module.
Old Aug 9, 2010 | 12:22 AM
DLP Performance
You'll probably be looking at $2,000 or so to install all that! If you go from 31s w/ 3.55s to 33s w/ 3.73s, you'll be in the same RPM range. No change. 4.11s w/ the 33s should give you the extra 300rpm or so.
The transfer case actuator is probably the culpret for no 4wd.
& Probably the switch in the dash for the rear window.
Old Aug 9, 2010 | 08:55 AM
Encho's Avatar
Encho
Go with the 4.11, the bigger tires will help you speed/wise, that 700 rpm estimate is that, an estimate. I have 3.73 stock diffs and i'm not happy with them, i run 2000 rpms at 75mph, so 4.11 shouldn't make that too much higher.
Old Aug 9, 2010 | 09:58 AM
DLP Performance
I just figured it on paper. You shouldn't see much over a 300rpm change from a 3.55 to a 4.11 with 31" stock tires at 60mph.
Old Aug 9, 2010 | 12:17 PM
Mavericks9's Avatar
Mavericks9
True, i went to the 4.11's. thanks for the advice.
Old Aug 9, 2010 | 12:42 PM
Encho's Avatar
Encho
Good think you could read this before you purchased the 3.73.
