just got mine at truck nationals yesterday and they don't change. I wonder if the constant and switched power has any thing to do with it? as far as I know they are wired up right, but they don't change off of red. thanks anyhow I will try calling them sometime soon.
All the constant feed line does, enables it to remember what color you were on when you turned off your key. Not switching color when the truck is running? Tells me that you have an issue with the gauge or the button itself.
yes they are the same I got but they will not change color, never did? I don't think it would be a problem with all three of the gauges at the same time. unless it is a wiring issue.
Yes I thank it is a wireing problem, in my last post I put where the wires are supposed to go. Keep us posted on what you find. We will help you out the best we can.
I have the exact same issue and was told it was wiring the glow shift tech. Call them they will help you with it. Ley me know how easy it was because ive been to lazy to figure it out
