Fuel Pump Advice
Old Aug 8, 2010 | 02:06 PM
49George's Avatar
49George
Fuel Pump Advice
I've been reading the stuff on this forum for months and it has been of great benefit. This is my first post. I have a Canadian built 1949 stock F1 (F47). It has been running great for two years but the fuel pump started leaking from a crack in the body of the pump. I bought a new one but can't seem to get it to work. I know the push rod is connected and I filled the bowl with gas to see if anything moved. Nothing did. I also discovered that my flathead is a 1951 year. My internet search said that the same pump was used from 48 to 52. I measured the push rod and it is the same length as the one I took out. The two pumps do not look exactly the same. The old one had the glass bowl mounted on top after the inlet and the new one hangs down from the same inlet.
Any ideas will be appreciated.
Old Aug 8, 2010 | 02:22 PM
jb50F1's Avatar
jb50F1
You didn't say if it was a six or eight. Here is a picture of the proper pump for the eight.
Old Aug 8, 2010 | 02:48 PM
49George's Avatar
49George
8 cyl
Sorry about that but it is an 8 cylinder. The pic looks nearly the same (inlet oriented the other direction). My new one has a "hanging bowl".
Old Aug 8, 2010 | 03:07 PM
jb50F1's Avatar
jb50F1
The pump in the photo is upside down, apparently it wouldn't stand up when oriented properly. There is a dual action pump that is similar. Any chance that you have the wrong one?
Old Aug 8, 2010 | 06:49 PM
ALBUQ F-1's Avatar
ALBUQ F-1
Welcome to FTE!
If the new pump doesn't work, either it's bad out of the box (not unheard of), there is an air leak on the inlet side, or the tubing from the tank to the pump is plugged (very common).
Old Aug 8, 2010 | 08:44 PM
49George's Avatar
49George
Thanks
The pump matches the picture. I'll check for leaks as mentioned.
Old Aug 9, 2010 | 08:54 AM
petey shoes's Avatar
petey shoes
welcome. you might try taking gasket out from under glass bowl and soaking it in fuel for a few minutes. they get dry in storage and just might be allowing air to be drawn in, causing loss of suction.
70-360fe
58
Feb 24, 2014 09:59 AM
RubberDuck
79
Jan 11, 2013 07:20 PM
chrismanjoa
Feb 18, 2012 05:05 PM
3414
Sep 2, 2009 11:57 AM
joe460
Mar 22, 2006 09:56 AM
