PSD won't start!
Old Aug 8, 2010 | 12:26 PM
Kelly MT's Avatar
Kelly MT
Question PSD won't start!
My 97 won't start. No smoke, filter is full, new cam sensor. It didn't start about 130 miles from home. I put in my spare cam sensor and it fired right up and ran home perfect. The next nothing it would not start. It tried a couple of times with a puff of white smoke. Now nothing. Any ideas? PK
Old Aug 8, 2010 | 06:16 PM
FARM69's Avatar
FARM69
Check fuse #22 in the engine compartment. It's for the fuel heater and they tend to short out once the wire in the fuel bowl becomes rusty and hits the wall.
Are you getting a wait to start light?
Battery's good? These engines need to crank over pretty fast in order for it to fire.
Check the wiring on the ICP/IPR for the possibility of shorting out. Probably not a common reason, but its a possibility.
Old Aug 8, 2010 | 06:59 PM
Action4478's Avatar
Action4478
If it is a hot start only issue ,You may want to check the IPR o rings ,, its cheap test ..
Old Aug 8, 2010 | 07:25 PM
fordpride's Avatar
fordpride
Check the wire's to the CPS (cam shaft sesor)
Old Aug 8, 2010 | 10:15 PM
Kelly MT's Avatar
Kelly MT
Thanks for the reply
I checked #22, good, new hot batteries. How do you check the CPS wires? Do you check pip to pin in the connector or continuity to a terminal somewhere else? Also, I get movement on the tack but it does not seem to be consistent.
The first failures to start it was hot, two hours on the road. The second no start it was cold. PK
broodog
34
Nov 2, 2022 12:39 PM
Sledge BC
1997 - 2003 F150
Nov 8, 2011 12:16 PM
G man 12
Feb 15, 2011 10:57 PM
Phoenixson
Oct 7, 2008 11:09 PM
JDS549
Sep 2, 2006 01:50 PM
